W56 tranny fits which transfer cases? And which clutch?
Old 09-11-2011, 02:39 PM
pyrojoe22's Avatar
Hello. I have a 1986 toyota pickup 4x4 with manual lock out hubs, 22R carb'd and 5 speed G54 tranny. I would like to know if the transfer case in my pickup will directly bolt up to a W56 tranny from a 22RE truck.
I'd also like to know if the clutch is the same for both tranny's.
Thank you
Old 09-11-2011, 06:09 PM
angrybob's Avatar
All the info you need is in the second sticky from the top.
Old 09-12-2011, 12:05 PM
pyrojoe22's Avatar
Called centerforce, and they said the clutch will work for both tranny's. He mentioned that the vibrations from the diesel may have ill effects on the clutch springs, however.
Old 09-13-2011, 12:37 PM
pyrojoe22's Avatar
okay so I got the info from the tranny that I want to buy today. The seller says it had a top shift t-case. So what do I need to do to make my forward shift t-case work with it? That's all I need to know and then I'm buying it.
SMOD
07-23-2015 10:29 PM
mYnAmEiSmUd
07-20-2015 06:48 AM
89hilux1
07-19-2015 01:32 AM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: W56 tranny fits which transfer cases? And which clutch?
