very mysterious coolant leak 22r
Old 09-30-2008, 04:13 AM
sethsyoter's Avatar
On my 86 i noticed a dried up stream of coolant under the exhaust manifold but it gets wet and then drys, but i can see that the stream stops before it reaches the head. only on block is the stream and it starts right where the little coolant pipe is that carrys the coolant to the heater core but i felt of the pipe and its not leaking. This has me worried that my block is leaking but i dont think it is the freeze plugs. its between the two on that side i think! What could it be?? help
Old 09-30-2008, 05:18 AM
Mr Priceless's Avatar
how many miles do you have on your pickup? hoses and clamps may need to be replaced
Old 09-30-2008, 05:20 AM
sethsyoter's Avatar
98k miles lol its wet where there is a little flathead screw looking thing at between the freeze plugs
Old 09-30-2008, 05:40 AM
misterzee's Avatar
Here's a hint: whenever you remove a hose, clean the surface of the pipe, and put some Permatex form-a-gasket #2, non-hardening gasket sealer on the joint... its the black greasy kind of stuff... not silicone... if you use this stuff, you dont have to sooooper-tighten your clamps, and it seals better.
** post a pic of your leaky area **
Old 09-30-2008, 05:59 AM
sethsyoter's Avatar
ok its nothing to do with hoses or clamps the flat head screw thing im describing is in the block it self between the freeze plugs on the exhaust side! i think its leaking around that screw
Old 09-30-2008, 10:37 AM
sethsyoter's Avatar
Bump, it looks as though it may be dripping down from exhaust manifold???
Old 09-30-2008, 03:54 PM
misterzee's Avatar
The only opening to the water jacket on the exhaust side is the drain that is at the back side of the block. If you have drippage coming from under the manifold... in the middle... then it is probably a headgasket....
WellsR
12
07-31-2015 03:27 PM
itzmywife's
07-25-2015 04:55 PM
cars-guy
07-11-2015 07:51 PM
87blyota
07-10-2015 04:31 AM
Avenged
07-09-2015 07:55 AM
Quick Reply: very mysterious coolant leak 22r
