toyota pickup ball joints and wheel bearings
Old 01-10-2009, 05:16 PM
84 yota ex-cab's Avatar
I am going to replace my ball joints and wheel bearings in my 89 toyota 4x4. Where do you guys buy them from? What brands are the best?
Thanks for any help.
Old 01-10-2009, 05:23 PM
Staff
DeathCougar's Avatar
If you get aftermarket parts, make sure they are good quality and preferably made in Japan.
Tripe5 parts are good quaility, as are Senkei (spelling?) Toyota uses Senkei parts in many of its vehicles.
Old 01-10-2009, 05:33 PM
Matt16's Avatar
Moog makes good parts from what I hear. I understand they are lifetime guaranteed.
Old 01-10-2009, 07:27 PM
scuba's Avatar
x2 on the moog Balljoints...
Old 09-30-2011, 03:17 PM
richard212's Avatar
Do the wheel bearings have to be pressed out on these trucks gonna change mine soon I know the Tacoma has to be pressed out
Old 09-30-2011, 06:09 PM
ccannon222's Avatar
Nope. They are the same as the wheel bearings used in the solid axle yotas. The races are a light press inside of the hubs. A good punch and bearing race punch set is all you need. Temkin makes good bearings that can be purchased at most local part stores.
Chris
Old 09-30-2011, 06:16 PM
richard212's Avatar
Do u have a write up or know of one to break down the hub Assy on them
Old 10-02-2011, 08:23 PM
bmcghie's Avatar
Here you go:
http://personal.utulsa.edu/~nathan-b...15componen.pdf
Everything in there should be pretty straight forward. I was a total mechanical noob when I tore into my hubs... 10k miles later, still good! I recommend a 54mm socket for the nuts, and at least a cheap torque wrench. Please don't use screwdrivers and a hammer to set wheel bearing preload!
Old 10-03-2011, 12:14 AM
wyoming9's Avatar
Smile
Do you not have a local auto parts supplier??
If they where selling poor quality parts nobody would buy them and they would be tired of all the returns.
As far as the wheel bearings you can take the numbers and go to your local bearings R` Us and get them.
Lots of good bearings out there. If you install them wrong even the best will fail.
ranma21
06-22-2015 11:55 AM
Mr.Black
06-21-2015 10:17 AM
AustinTaco
06-21-2015 09:54 AM
paxanders
06-21-2015 06:29 AM
88Toy
7
06-17-2015 09:40 AM
Quick Reply: toyota pickup ball joints and wheel bearings
