Toyota 4Runner 95' fuel injectors replacement
Old 10-19-2016, 02:32 AM
yogev's Avatar
Originally I had a brown "denso" fuel injector, the correct model for my engine 3VZE (this injector has one hole CC/min-200,OHMS 1.7, lbs/HR-19.6, kPa-290)
i switched those injectors with light green "denso" injectors (he has 2 holes but I'm not sure what is the correct model here is a denso chart: http://club4ag.com/faq_and_tech_pages/Toyota_Injectors_Specs_Data_Denso.html )
I suppose the new injector has a bigger flow rate and I should Increase the amount of air entering the engine.
What do you suggest, how could I Overcome the problem? The new injector
The new denso injector
The old brown injector
The old injector
Old 10-19-2016, 04:19 AM
robertd33's Avatar
that's not how it works.
even if the new injector had 1, 2, 6, or 10 jets, it would still be metered for the correct flow rate.
Old 10-19-2016, 06:17 AM
yogev's Avatar
The specs of the new injector show that the amount of fuel is bigger.
I seiches between the injectors, and now I feel that the car is heavier in the bagging of the drive.
Old 10-19-2016, 06:18 AM
yogev's Avatar
Tnx 4 the Quick response
Old 10-19-2016, 05:18 PM
robertd33's Avatar
might want to confirm you got the correct one.
the ECU expects X amount of fuel to coordinate with its programmed air/fuel/fire management.
changing one of those will throw off the curve.
