tires?
Old 10-14-2015, 09:08 AM
scott90yota4x4's Avatar
tires?
hey guys got a couple questions Can I put 32 in (31.3 exactly)11 1/2 wide on a 89 yota 4x4 with no lift? will they rub and do you think 11 I/2 is too wide n heavy for a 4 cl with stock gears. any info will help Thanks
Old 10-14-2015, 12:53 PM
mwisham's Avatar
You can put those tires on there w/o a lift, but I don't think you would be happy with them. If you don't change the gear ratios, you will see a pretty good drop in performance. I would recommend 31X10.50's max.
Old 10-14-2015, 08:36 PM
muddpigg's Avatar
Sure you can put them on. I had 33 (actual size was a bit smaller) on stock gears when I got rig. Doable but not optimal. If you live someplace with lots of inclines, gonna be worse. manual tranny or auto makes a difference too.
Old 10-15-2015, 10:40 AM
highonpottery's Avatar
they'll fit, but like said already I'd just go with a 31x10.5 unless you're driving on sand or terrain where the extra width is necessary, I'd stay with the slightly skinnier tire that's essentially the same height and weighs less and with less resistance...and possibly cheaper too.
Old 10-16-2015, 04:48 AM
thanks for the info.
that's exactly what I'm gonna do
Old 10-17-2015, 02:51 AM
AKHeathen's Avatar
i've run that size for years... like a decade.... but variables, as mentioned
Rosco1977
10-22-2015 12:31 AM
1980crawler
10-14-2015 03:25 AM
9322rerunner
10-10-2015 07:04 PM
jumpersatthedoor
10-09-2015 01:12 PM
Quick Reply: tires?
