timing belt job. who's got PN's?
Old 08-27-2008, 05:21 PM
gtfourdreams's Avatar
ive been lounging around the forums for awhile now, mostly reading tech articles and stuff. i tried the search function and found some good information on the timing belt job, but i couldn't find any part numbers for stuff. does anybody have the part numbers for OEM Toyota parts to do the job? I want to do the whole works, ie. timing belt, tensioners, water pump and oil pump, etc. this is for a '89 SR5 V6
FYI, my truck has 225k miles on it, and the sticker on the engine says the timing belt was done in '92 with 87k miles on it. that means i am at 15yrs and 135k miles on that timing belt. i think its really time to do that timing belt.
UPDATE: for future reference, I ended up purchasing these parts from Gerone at toyotapartsales.com/trdparts4u.com. I felt the need to replace the Water Pump and the Oil Pump, so I ordered the seals to go with.
13568-69055, Timing Belt
16100-69225, Water Pump Assy, Cooling
13503-65010, T-belt Idler Assy (top w/water neck)
13505-65020, Idler Sub-Assy, T
90916-03079, Thermostat
16341-35010, Thermostat Gasket
extra for oil pump:
15100-65020, Oil Pump Assy, Engine Fr Cvr
90311-40022, Crankshaft Seals
and here's a picture of my timing belt (OEM part), taken out with ~135k on it. there are cracks on every single tooth section of the belt and the picture shows the worst part of the belt where it is beginning to deteriorate.
Last edited by gtfourdreams; 10-14-2008 at 08:17 PM. Reason: updated pn's and picture
Old 08-27-2008, 05:39 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Try here: https://www.yotatech.com/forums/f116...umbers-102344/
Old 10-06-2008, 06:18 PM
ok this is what i have for my '89 SR5 3VZE 5spd. am i missing anything?
16572-65010, Hose, Lower Radiator to Thermostat
Old 10-07-2008, 08:56 AM
FormerVendor
TRDPARTS4U's Avatar
thermostat gsk is not included with the thermostat pn 16341-35010
while you have it torn down check your seals:
camshaft 90311-42027 x 2
crank 90311-40022
Gerone
Old 10-07-2008, 03:43 PM
i just also noticed i was missing the other timing belt idler. i believe i'll need that too, right?
plus, if i get those camshaft seals i should probably get the valve cover gasket too?
11213-65010, Valve Cover Gasket
hmm.. this is adding up fast. :p
Old 10-08-2008, 05:51 AM
FormerVendor
TRDPARTS4U's Avatar
Check your PM's, I sent over pricing on the items you inquired on.
Thanks,
Gerone
Old 10-09-2008, 03:47 PM
frankh's Avatar
Timing belt
Hi guys,
I have a 95 4 runner with the 3.0 V6. Locally I can only find the spring tensioner timing belt kit (which I assume comes with new pulleys spring etc).
I don't know if I have a spring or hydraulic tensioner in there..Is it easy to fit the spring kit in place of the hydraulic kit?
I will change the water pump but I assume the stud/hook to hold thr spring won't be there...Is it easy to fabricate this?
Detailed instrcutions welcome..
Thanks
Frank
Old 10-10-2008, 04:53 AM
FormerVendor
TRDPARTS4U's Avatar
FrankH, I just PM'd you the OEM part numbers and pricing.
Thanks,
Gerone
Old 10-14-2008, 05:25 PM
for the record, i just got my parts from toyotapartsales.com (toyota of dallas) it came faster than expected and a great price. definitely will get my business again in the future. thank you gerone!
now... if i could only find some better directions for removing/installing this oil pump.
Old 10-14-2008, 08:16 PM
i added pictures of the belt i took out and the parts i needed for the job on the first post, for future reference.
Eggslinger
06-08-2019 03:32 PM
TURBOrunnerNM
07-22-2015 11:01 AM
nick b
07-11-2015 04:38 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: timing belt job. who's got PN's?
