timing
Old Nov 17, 2007 | 03:15 PM
acerbis's Avatar
timing
My vetc label say to be at o degrees for timing. that doesn't seem right. An i think i saw some people on here at 12 or something. what are you guys running on a 4 cylinder 87 carburator. (22r??)
Old Nov 17, 2007 | 03:21 PM
billmaness's Avatar
My '90 says 12 deg @ 800 rpm.
Old Nov 17, 2007 | 03:27 PM
tc's Avatar
tc
The 12* you're reading is probably for V6...
I used to tune my '89 22R by ear/tach. Adjust the idle speed, then the air/fuel screw to the max RPM, then the timing to the max RPM, then dial the idle speed back down. You may need a little tweak of the air/fuel and timing after that, but probably not.
Old Nov 17, 2007 | 03:31 PM
acerbis's Avatar
so you adjust the air/fuel screw untill the rpm rises no more, then adjust the timing untill it doesn't climb. go back and adjust you idle to 700 or so and it should be perfect?? Just for kicks what did your timing end up at??
Old Nov 17, 2007 | 04:08 PM
Flash319's Avatar
oops I reread 22R.
Old Nov 17, 2007 | 09:25 PM
tc's Avatar
tc
Yeah, you'll actually hear it start to come down, then back off a little.
I never really checked with a timing light. NEVER had any knock/ping so didn't worry about what the number was.
Old Nov 17, 2007 | 10:05 PM
SCYOTA's Avatar
Yes it supposed to be at 0 degrees with the vacuum lines on the distributor disconnected. Set it with a timing light to 0 degrees and your timing will be correct. When you hook your vacuum lines back up the timing should advance to about 12 degrees.
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
smiley52
Jul 11, 2015 05:16 AM
