Switching out gauge cluster with SR5 gauge cluster
Old 04-02-2009, 10:49 AM
desconhecido's Avatar
My understanding is that 91 and earlier are cable, 92-94 are electric, and some say that 95 is cable again, but I don't know that for a fact.
Old 04-02-2009, 07:18 PM
mmcpeck's Avatar
I know for a fact that my '91 Runner has a cable, because it makes a hell of a lot of noise behind the dash when it's cold out.
Not sure about my '92 Pickup, just got it a day ago. I guess the safest bet would be to try and find a gauge cluster from the same year, if possible, and from a 5spd, although I still don't see what difference a tranny would make to a Tach.
Old 04-02-2009, 07:25 PM
iamsuperbleeder's Avatar
I'm such a sucker... guess what I just bought guys
I'll give you a hint:
Old 04-02-2009, 07:49 PM
mmcpeck's Avatar
superbleeder.....report back with any knowledge when you put that thing in. I will be doing mine next weekend with any luck....no time this weekend.
Anybody know for sure what kind of speedo a '92 has cable or electric?
Old 04-02-2009, 08:28 PM
  #25
should be pretty straight forward from what I gather
1) swap the gauges
2) swap the oil pressure senders
3) if the tach doesn't work right away, run the jumper wire
I've been meaning for the longest time to pull the gauge cluster out and replace the bulbs in it anyway; I guess this is just as good
no to mention, it's costing me less than it would to go full electric aftermarket gauges instead of the manuals I have now
now I just need to find another piller trim peice, cause my stock one is now rittled with holes from the install of these aftermarket gauges
and I don't think I've ever contributed a good write-up to YT, so I might give that a shot when I install them
Old 04-02-2009, 08:45 PM
  #26
mmcpeck's Avatar
Well let me know if your '91 has the tach wire in the harness.....then I can hope my '92 has it also.
Old 04-02-2009, 08:54 PM
  #27
will do buddy
I'll post back here with the results, and then a little later post a write-up thread
oh, and I guess I can post a full picture of my purchase, in case my hint wasn't good enough for some people
I heart eBay $66
anyone know how to turn the odometer up, so that I can match it to my current 295 thousand, lol guess I'll have to figure that one out; shouldn't be too hard. I like the fact that I'll have a mileage odometer-trip now too I just noticed that, lol
Old 04-02-2009, 09:27 PM
  #28
mmcpeck's Avatar
Hahaha....I was actually looking at that one earlier, but the guy confirmed that after '92 they don't have the mechanical speedo cable anymore.....glad somebody is gonna put it to good use.
Now I just have to find out if they used the electric speedo in '95 and I will have a nice gauge cluster for my truck.
By the way, on a side note, do the electric speedo's show the speed off if you put bigger tires on? I know the mechanical cables do.
Old 04-02-2009, 09:29 PM
  #29
haha, yeap; I snagged it!
about the tire size throwing the speedometer off, I would think so; isn't the speed sencor in the trans, much the same way the cable runs to the trans?
Old 04-03-2009, 08:55 PM
  #30
now I'm debating if I want to keep my current theme with the stainless steel insert:
and go ahead and buy one of these to install too:
but at the same time, I kinda just wanna leave it stock looking...
I dunno what the hell I wunna do now, lol
IMO, it looks pretty neato... with the aftermarket guages and everything else in the cab... but those are going out the window when the SR5 cluster goes in, so I'm not sure it'll fit in...
Old 04-03-2009, 09:35 PM
  #31
abecedarian's Avatar
if the new odo has less miles than yours you could hook a drill up and spin it till you get the correct mileage... if not... not sure about your locale but out here in Cali you can file an affadavit with the DMV disclosing the original odo reading and the replacement odo reading (technically out here, you're supposed to do that when replacing the odo anyways).
Old 04-03-2009, 09:39 PM
  #32
well the cluster can't be all that hard to take apart
I had to take my standard one apart when I installed the stainless insert, so I have the gist of it anyway
we'll see; depending on how many miles of a difference we're looking at, it might take a WHILE to do the ol drill trick, lol
and setting it to the true milage, I don't believe there would be any legal issues I'm probably wrong, but I'm not gunna sweat it... I've done "worse" things to this truck... cough, cough, no-cat, cough, cough
Old 04-03-2009, 09:40 PM
  #33
there's always the 30k rpm moto-tool...
dental work anyone?
Old 04-03-2009, 09:41 PM
  #34
dental work anyone?
lol, well I'd be afraid that trying to wind it up fast would just damage it...
or just wear it out so the speedo will bounce like all the high milage ones, lol
Old 04-03-2009, 09:43 PM
  #35
yeah, maybe going 682 miles per hour could cause a problem?
maybe you'd get a sonic boom from the speedo needle?
Old 04-03-2009, 09:44 PM
  #36
lol, well I garantee you it would be the only time that speedo would see anything over 90 MPH
Old 08-07-2009, 05:33 PM
  #37
JeepRecoveryINC.'s Avatar
I attempted to do this swap in my 89 4Runner last night and ran into all sorts of problems. I disconnected the battery before starting and got the gauges and oil pressure sending unit swapped but I'm having issues. With a half tank of gas it shows full, temp gauge goes straight to red, tach does not register though it appears to be wired for it. The only things that seem to work are the oil pressure gauge, volt meter, and spedo. Please give input.
Old 08-08-2009, 07:28 AM
  #38
see that's weird; mine was a direct drop-in with my 91 PU, using a cluster from a 90 4runner
https://www.yotatech.com/forums/f116...w-pics-179106/
Old 08-08-2009, 11:32 PM
  #39
Copliesflip's Avatar
I have a '90 truck and am looking to do a cluster swap to something with a tach and the only part that I am still a bit shaky on is switching the oil pressure sender. A quick how to on that part would be great.
Thanks all
Old 08-09-2009, 06:05 AM
  #40
foot0069's Avatar
This link helped me out.
Jim
http://www.mindspring.com/~jayk3/toyota/tachmod.htm
At the bottom of this artical it talks about the little white screw. Thats all I needed to trim the V6 cluster I installed in my 91 4 Cyl. I did borrow an old dwell - tach meter from a local shop to read the rpm's as I set it
Quick Reply: Switching out gauge cluster with SR5 gauge cluster
