Stupid annoying driver door!
Old Oct 4, 2006 | 07:01 PM
94toyota4x4's Avatar
Thumbs down Stupid annoying driver door!
My door gets so annoying sometimes, it closes but you can hear air coming in, and its real losse, it has the padding what can I do about this?
Old Oct 4, 2006 | 08:46 PM
Bob_98SR5's Avatar
so is something loose? door panel?
do you have a rubber door gasket? if so, is it torn?
im just not understanding what you are describing
bob
Old Oct 5, 2006 | 02:12 AM
HAVOC's Avatar
First thing is to see what's loose.
Here is my trick for finding air leaks:
Make sure the door seal is on good. Then close the door and get masking tape. Tape up one section at a time (bottom, top, etc.). Your going to tape the gap between the door and fender for instance. Get it the pass. side and drive the truck. Did it get worse or better? You could try to tape the entire door if you like. Get out remove some of the tape (or add more) and drive the truck again until you find the location of the wind coming in. It's time comsuming, but it works.
Old Oct 5, 2006 | 04:00 PM
I have the rubber gasket and its fine but the door likes to jiggle letting noise from the out side in. I ll check it out tonight
westonian18
May 1, 2020 06:38 AM
mussy01
Dec 13, 2016 08:20 PM
theking11863
Mar 19, 2016 09:36 PM
94yotaky
Jul 23, 2015 07:50 AM
coryc85
Jul 6, 2015 04:07 AM
