Strange ticking noise on driver's side 3.0
Old 04-14-2014, 05:57 PM
wanayota's Avatar
This strange tick has been going on for years now. I have not noticed a loss in power or any serious valve train malfunctions..yet..but it is on the driver's side somewhere up top. I have used a mechanics stethescope (screwdriver) on the valve cover, fuel pressure regulator (replaced anyway) and the fuel injectors. I have also tried unplugging the plug wires one at a time and still the tick remains. The only time I heard any sound through my screwdriver was when i placed it on the exhaust manifold section for the #1 piston. The tick occurs AFTER the engine is warmed up and ONLY occurs when i am engine braking (5 speed) between 1700 and 1200 RPM then disappears at idle. WHAT IS THIS THING!?
Old 04-14-2014, 07:20 PM
nv4runner's Avatar
I'm thinking exhaust leak. I'd check how tight the nuts are where the manifold and crossover connect to the down pipe. Might even need a new gasket in there if it is leaking.
Old 04-14-2014, 07:41 PM
wanayota's Avatar
Ive often thought that donut gasket was bad but there isn't any black deposits that I can see? I had a new one from Autozone and it just rolled around in the back and I eventually returned it. I just didn't want to snap off those studs. My old man did that…not a fun fix. Ive heard that the heat shield can cause some issues as well? Rattling, vibrating and the whole range of funny noises?
Old 04-17-2014, 04:51 AM
92yote4x4's Avatar
mine does samething, i just thought it was the valves opening and closing?
Old 04-17-2014, 09:12 AM
wanayota's Avatar
I was always under the impression that if it were the valve the noise would be there all the time not just at certain RPM ranges?
Old 04-17-2014, 09:58 AM
92yote4x4's Avatar
its the lifters.....jk lol but i would think it would be something to do with the valve train, try checking clearancesbetween cam and shim?
Old 04-17-2014, 10:08 AM
wanayota's Avatar
I will have to do that when i replace my leaking valve cover gaskets. I may or may not have tightened down the valve cover too tight. I heard this will cause the cam to tick against the valve cover?
MTLroadierunner
07-15-2015 12:58 PM
razorman8669
07-12-2015 12:13 PM
smiley52
07-11-2015 05:16 AM
Gamble_STi
07-07-2015 07:54 PM
coryc85
07-06-2015 04:07 AM
Quick Reply: Strange ticking noise on driver's side 3.0
