squeaky brake pedal
Old Apr 20, 2006 | 05:19 PM
wailukutoy's Avatar
squeaky brake pedal
Hi everyone. My truck's brake pedal is driving me insane. Everytime I release the brake pedal after braking, it makes a loud squeaking sound. Anyone know what this might be and how to fix it. Thanks for the help.
Old Apr 20, 2006 | 07:49 PM
Bobakazi's Avatar
Is the noise from inside the cab? Get on your back on the floorboard, put pressure on the brake with your hand, notice what moves, and lube it all with some WD-40 or better lubricant. I like the Slick 50 lube.
Old Apr 20, 2006 | 08:02 PM
bigpest88's Avatar
Hey, mine squeaks too, but if you turn up the radio, you wont hear it. I never hear it until I lower my radio, but I cant even hear myself with my two 12inch woofers.
Old Apr 20, 2006 | 08:06 PM
miket223's Avatar
Sometimes a leak will develop from the vacuum booster and funny noises will come from the firewall.
Old Apr 20, 2006 | 10:49 PM
wailukutoy's Avatar
the squeaking is from inside the cab. I will try and see if I can lube up the parts. thanks for the help.
Old Apr 21, 2006 | 05:17 AM
regularguy412's Avatar
Mine does the above occasionally, when I step on the brake. The high-pitched whistling nearly drove me nuts until I figured out what was causing it. I thot it was the tach goin' out. Now when it does that, I just move the brake pedal a small amount and it usually goes away. I'm not looking to tear into my booster,just to replace a seal. Since it doesn't make that sound when I'm driving, I'm pretty sure there is no vacuum leak.
Mike in AR
fountain
Dec 31, 2015 06:08 AM
RBK
Aug 2, 2015 11:33 AM
ty1er
Aug 1, 2015 11:53 PM
PopsDad1
Jul 30, 2015 02:21 PM
