Spuddering Idle, fine after a while
Old 06-07-2010, 09:29 AM
86bedlesstoy's Avatar
Start the 86' up in the morning and it will run with a miss but after working up and driving less than 2 miles it idle just fine.. I do live at 9,986 ft. haha Just installed new NGK singles and it does sound better. Revs up with a little more power. Still super quiet though. I was thinking check out the Idle adjustment scrw on the carb. Also What is the two lines that run above the parking brake adjustment under the bed? Think I have a leak. Be crawling under her later.
Old 06-13-2010, 08:22 AM
I'm guessing I must have cracked the one of the spark plugs when installing them. On 2 of them it was very tough to get the socket off so I had to wiggle it some. It's been raining for a couple days and haven't had time to check it out. Runs great after it's nice and warm.
Old 06-13-2010, 08:32 AM
hilandfrog's Avatar
IACV.....
Idle Air Control Valve...:cry
https://www.yotatech.com/forums/f116...needed-209901/
https://www.yotatech.com/forums/f116...k-like-143319/
Repo
Old 06-14-2010, 10:18 AM
Buy a new one?
Old 06-14-2010, 10:21 AM
I could see how the Idle Air Control Valve would be a problem. So you can clean it out? Guessing it would be hard to fine a new IACV?
Old 06-14-2010, 10:59 AM
$200 plus shipping! Ouch
Old 06-14-2010, 11:17 AM
So is there anyway I can check if that is really the problem?
Old 06-14-2010, 11:29 AM
hilandfrog's Avatar
There are a few threads out there...
I took mine completely apart and found NO SOLID answers.
My truck runs great at temp.....
studdering at 4-500 RPM when cold, must use gas peddle to start, and keep running for 15-20 sec.
One poster responding to my thread stated each full rotation of the cap holding plunger in =~200RPM.
I screwed the cap in 9 1/2 times, Ill try turning it out:dunno more air and see if that helps.. may be a day or 2.
Good luck
Repo
Old 06-14-2010, 11:34 AM
Yeah, It runs great after reaching temp but idle is sloppy. This truck doesn't have a IACV! It uses the carb dude. All circuit run off that. Looks like I might need to adjust my idle adjustment screw and clean the whole guy with carb cleaner.
Old 06-14-2010, 08:28 PM
hilandfrog's Avatar
Well I'd guess it isn't your IACV then
Repo
Old 06-15-2010, 07:20 AM
I have a 22R, Not a 22RE! Finally sunny, I'll be checking it out in a while!
Old 06-15-2010, 11:05 AM
Went all the way in, Then adjusted till it sounded much better. Took it wheelin' right after and she worked great as usual. I still have no horn though.. wth
Old 06-20-2010, 07:55 AM
So the truck has be running with a misfire. It started at only idle but now it is popping when letting of the pedal and such. Still think I might have cracked a porcelain on my plugs. It did not run like this before at all. Big change since the plugs where changed.
Sleaker
08-26-2020 06:03 AM
Eggslinger
06-08-2019 03:32 PM
_Nicco_
08-28-2015 07:26 PM
ddg71
07-24-2015 01:24 PM
kyletbert
07-17-2015 11:39 AM
Quick Reply: Spuddering Idle, fine after a while
