Spongy brake pedal nightmare.
1 Post
Anything? I have the same problem with my 89. Granted I can still lock it up on pavement, there's just a lot of travel in the pedal. I wasn't sure where to start, so maybe I'll just leave it.
Staff
After sitting for a few days, I disconnect the lines from the wheels and use a low pressure air hose and blow it out from the MC connection to the wheels to keep from getting a mess in the engine compartment. After I get all of the PB Blaster out, I reverse the flow from the wheels to the MC. There is alot of corrosion in these lines.
If I recall right, one of the metal lines on the rear of the frame is no longer available from the dealer. One reason I use low pressure air so as not to blow out a line.
After you get the lines cleared, you can get an idea of how well the lines are cleared by the way the air will flow thru them. I do this on projects and if you have another means of transportation, it might be feasible for you to do. Mostly just out the cost of some brake fluid. To keep the PB Blaster out of your wheel cylinders and calipers, maybe you could plug them with some golf tees or something similar.
I'm pretty sure high pressure air shouldn't be a problem to blow out the lines. Under hydraulic pressure these lines see 1000-1500 psi. If a 100psi shot of air is going to blow it out, consider it a good thing...you just found a weak link.
Staff
I had thought about that being a good thing on finding the weak link with high pressure air, just wasnt sure how to word it and make it sound right. Thanks!!! The rear part of the frame and especially on a pickup the brake lines can get in bad shape around the fuel tank up to the Proportioning Valve.
Shaun Crystal Gomban
07-30-2015 10:13 PM
PopsDad1
07-30-2015 02:21 PM
