So let's get into it
#63
Oil pan is on along with the rear main seal.
rear main bolts torqued to 61 in-lbs
oil pan bolts torqued to 82 in-lbs (slightly higher then spec)
i I primed the oil pump slightly with 10w-40 but will prime it again before starting.
#65
Here is a comparison between the 3vze and supra VAFM.
On the air box side you can clearly see the supra is clearly a little larger.
From the top they are very similar.
The throttle body side is a huge diffrence in size.
And now for the air box side gasket. I stacked the 3VZE gasket on top of the Supra gasket. You can clearly see the size diffrence.
#66
Power washing all the misc parts and detailed the engine bay. Tomorrow we are starting out by dressing the bottom end and then replacing the transmission input seal. After that it's time for the assembled short block to go back in.
#69
Clutch is is all bolted up. Torque plate torqued to 65ft-lbs and clutch torqued to 14 ft-lbs. it took a little work but the input shaft is in and she is resting on the motor mounts.
#73
Location: exo-reality -wave if you see me; Front Range, CO
13th head bolt
Hiya CBR
Progress is looking good. I see you marked your clearances. Cool idea. I gotta put up a separate post after a search on that.
What I wanted to ask is that 13th hex-head bolt for each head: Is that a shoulder head bolt? I think its a 10x 1.25, but I'm not sure, and probably less than 40mm long?
I think I found one, but its too long by about a few mm's. Can't find the other that might match. Took these off like 5 years ago and the 'permanent' marker on the bags has evaporated on lots of them, and I guess I just spazed out when marking some of them, and apparently just threw some stuff away.
Sorry for the double spacing. whiskey tango...
#77
Hmmm. Those look familiar! Do they fit back there in that '13th' place? Those are your hex-head Head bolts I mean?
Geez. Guess if that's the correct placement for yours, I get to go 'chopin. whoopee doo. more money. Let me know eh?
And Thanks!
And Thanks!
#78
Yeah I think that's correct. They have unusual heads and a fine thread that matches the head bolts. I think the steal spacer helps add a little support on the thinner section of the aluminum head. One goes on the drivers side head on the front. The other goes on the passenger side at the rear.
#79
What a pain this has been but making some progress.
Head bolts torqued
120 in-lbs
240 in-lbs
35 ft-lbs
+90 degrees
+90 degrees
all bolts marked at the 12 O-clock then turned to the 3 O-clock and finished in the 6 O-clock. Checked torque and bolts seem to be around 105 ft-lbs roughly.
cams installed and caps to torqued to 144 in-lbs. FIPG used on the front and rear sections along with all new cam seals front and back.
exhaust cross over is all bolted up with new crush rings.
intake manifold is all bolted up and torqued to 156 inch pounds.
