Replacing plug wires
Old Mar 11, 2006 | 07:00 PM
Toyo4x4's Avatar
Question Replacing plug wires
How often should this be done?
A new set was put on about 9 years (~100K) ago so I'm wondering if it might be something I should consider.
Old Mar 11, 2006 | 07:20 PM
Avsfreak1234's Avatar
plug wires are cheap enough, and they are so easy to swap that you should just do it. even if your rig runs fine with 100K on the wires
Old Mar 11, 2006 | 08:13 PM
ChickenLover's Avatar
Yeah, I'd say you are due for a new set of wires. Be sure to get OEM wires. That cheap aftermarket crap has no place on your rig.
Old Mar 11, 2006 | 10:49 PM
kyle_22r's Avatar
i ran autolite wires once on my '79, never noticed any differences. then again, they probably wouldn't have lasted 10 years, but i think plug wires are a wear item that should get replaced a lot more than that
i call it the "OEM placebo effect"
Old Mar 12, 2006 | 08:16 AM
sandcrawler's Avatar
yeah, i'd say you're definitely due. and i second chickenlover's recommendation of the OEMs.
i have some NGK (blue) wires i got through sparkplugs.com (i think) for like $35/set, but although they are supposed to be (as good as) OEM i suspect they aren't as good as the ones you'll get thru toyota; my idle can fluctuate and sometimes at startup it hesitates a bit.
Old Mar 12, 2006 | 02:19 PM
Elton's Avatar
i change mine about every 10k miles also you can get denso plugs wires for 43 bucks at www.sparkplugs.com
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
steve miller
Oct 10, 2015 01:40 AM
toyota32
Jul 6, 2015 05:42 PM
colinmil
Jul 6, 2015 04:03 PM
elwood73
Jul 5, 2015 07:07 AM
