Rear wiper won't turn off!
Old 04-07-2008, 03:49 PM
gray420's Avatar
Hey all,
I just put the top back on the runner and rolled up the window. When it got all the way up there was a pop and the wiper started going. Now it won't turn off and I can't get the window down. Any ideas?
Old 04-08-2008, 05:34 PM
leebee's Avatar
disconnect the wiring (in the left rear corner) for the wiper/washer, that will allow the window to operate. you will have to check the wiper motor assy for possible electrical short as well as the wiring.
lee
Old 04-08-2008, 06:04 PM
gray420's Avatar
tried that already, no luck.
Old 04-09-2008, 04:57 PM
leebee's Avatar
if you disconnect that plug and washer fluid tube, the wiper will NOT work. there will be NO electrical current flowing to the wiper motor. if there is, then someone has done some extra curricular wiring mods.
have you checked/cleaned the switch up front? there is something wrong somewhere, electrical gremlins are not the easiest to find and correct. maybe pm 4crawler, he is an electrical engineer and might be able to help you out.
lee
Old 04-09-2008, 09:22 PM
gray420's Avatar
Thanks for the reply. The wiper turns off when I undo the plug at the back, but that doesn't make the window work. I'm putting this off for a bit as I just took out the windshield and have some serious rust issues to tackle.
Old 04-09-2008, 09:26 PM
sleaz22xx's Avatar
just had the exact same problem, turned out the window/wipe relay had gotten wet
Old 01-08-2011, 08:57 AM
gbftats's Avatar
did you just replace the relay?
My wiper is doing the same thing.
Old 01-08-2011, 09:05 AM
gray420's Avatar
Sold that truck last year, but if I remember, I just replaced the switch and everything was ok.
jerusry
10-19-2015 05:28 PM
Kalihi,HI
07-09-2015 04:29 PM
icentropy
07-09-2015 02:12 PM
87turboPA
07-09-2015 05:58 AM
raiderhawks00
07-08-2015 06:23 PM
Quick Reply: Rear wiper won't turn off!
