radiator leak/high idle and surge
Old 02-28-2011, 09:39 AM
4x4jeffyota's Avatar
Would a leaky radiator contribute to a high idle and a surge? any help would be awesome
Old 03-01-2011, 04:58 AM
RatOmeter's Avatar
I don't think so, but not an expert.
My 94 22RE surges when the outside temperature is below around 40 F. In my case, the problem is the auxiliary air valve. The passages where coolant is supposed to flow is completely packed with crud... a product of me not flushing the cooling system for years at a time.
Aux air valve:
Old 03-01-2011, 05:02 AM
GeeVee's Avatar
Not sure. Do you have all the emissions, vacuum hooked up?
Old 03-01-2011, 05:18 AM
mightymouse's Avatar
yes, A radiator can and will relate directly to a high idle and surge. The auxiliary air valve posted above is directly affected if it gets no coolant or air bubbles. Fix the leak, refill the system and purge it of any air bubbles.
smthwsn357
12-04-2023 02:08 AM
Sleaker
08-26-2020 06:03 AM
Road Bull
10-10-2015 04:55 PM
Dakotaneu
07-27-2015 12:03 AM
Logz808
07-26-2015 07:09 AM
Quick Reply: radiator leak/high idle and surge
