power loss, clueless on what it could be
Old 01-29-2010, 07:59 AM
headstomp3's Avatar
hey guys, in the past couple of days my car has been very sluggish acclerating 2nd-4th gears from 2500rpm-3500rpm. what should i check. i have planned to check my plugs, wires and cap to check everything is tight, i have been doing a little offroading in arizona going over some rocks so it has been shaking alot. any ideas???
Old 01-29-2010, 08:22 AM
CappyKD's Avatar
Baseline it first. Give it a treatment or two of Seafoam, change the Cap, Rotor, plugs and wires Use all OEM parts. Then see where your at.
Good Luck
Old 01-29-2010, 08:24 AM
headstomp3's Avatar
i had the cap, rotor, wires and plugs changed in may, have put about 5k miles on them
Old 01-29-2010, 08:40 AM
CappyKD's Avatar
OEM Parts? (Toys don't like non-oem ignition parts) Have you done the fuel filter? Checked for vacum leaks? Have you checked the timing?
Old 01-29-2010, 09:22 AM
headstomp3's Avatar
i havent done the fuel filter, they are oem parts... vacum leak is a good thing to check... i have the manual but off the top of your head, is the filter in line or in the tank? the timing was done when i had all accessory belts replaced the same time the cap, wires and plugs were serviced
Old 01-29-2010, 09:34 AM
CappyKD's Avatar
The fuel filter is inline next to the passengers side frame rail. Easy to replace. Get the OEM one as it come with a new bracket. Have you checked for CEL codes? Have you checked or had checked the exhaust valve adjustment.
Old 01-29-2010, 09:47 AM
headstomp3's Avatar
what is CEL codes? diagnostic?
Old 01-29-2010, 10:13 AM
CappyKD's Avatar
Yes you jumper two terminals under the hood then turn you key to on. and check the flashes of the check engine light. The procedure for pulling the codes on our runners is here somewhere.
You also may want to check the TPS for adjustment.
Old 01-29-2010, 10:50 AM
CappyKD's Avatar
link to how to pull the codes.
http://www.4crawler.com/4x4/CheapTri...CheckConnector
Old 02-03-2010, 07:54 AM
headstomp3's Avatar
so i started with the fuel filter and that fixed the power loss, but the gremlins just keep coming!! my power steering is pissing fluid and now it is idling around 2000 rpm i cant get ahead with this thing
Sleaker
08-26-2020 06:03 AM
JaredL
03-28-2016 09:08 PM
Tacoma1313
08-17-2015 05:44 PM
nate2919
08-06-2015 04:00 AM
gmonnie123
07-26-2015 02:44 PM
Quick Reply: power loss, clueless on what it could be
