Please help! tach troubles? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-27-2008, 06:53 PM   #1 (permalink)
I've looked around the site a little, but can't seem to find much. Can't figure out where I put my manual either, otherwise I would have checked it, but....
My tach is acting up. It sometimes works fine, but when it doesn't it misbehaves in one of two ways... (truck is '88 4runner, 22re 5speed)
-totally misbehaving: erratic needle wandering, bouncing anywhere from 0-redline numbers regardless of throttle
-kinda misbehaving: erratic needle wandering during off-throttle (coasting)
Could this simply be a loose wire? My initial thought was a sending unit, but with no manual at the time to help me diagnose, I guess it could be the tach itself. Thoughts? Best way to troubleshoot this? I'm not sure if the tach/sending unit can be tested, and I'm a beginner when it comes to using my multimeter.
Thanks!
-Chris
babyfood1217 is offline
Old 08-27-2008, 06:58 PM   #2 (permalink)
Bigblock's Avatar
Sometimes bad plugs,wires,cap or rotor can cause this.Or the ignitor.More than likely it's the tach itself.
Bigblock
Bigblock is offline
Old 08-27-2008, 07:03 PM   #3 (permalink)
I guess I should add that it engine performance doesn't seem to be affected at all (no reliable tach to look at, but...). I found a few posts about high idles and surges, but it's not really the engine. I just put new plugs/cap/rotor in about 5k ago, but not wires.
Old 08-27-2008, 07:10 PM   #4 (permalink)
Bigblock's Avatar
I had a tach quit all together but it didn't act a fool first.
Bigblock
Bigblock is offline
Old 09-23-2008, 04:51 PM   #5 (permalink)
ffryno13's Avatar
i cant figure out how to mount my tach there is no coil post to connect it to. any advice would be great.
ffryno13 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
82 troubles still WSUWESTON Pre 84 Trucks 2 05-04-2008 07:05 PM
SR5 tach cluster upgrade question...no tach vwfastg60 86-95 Trucks & 4Runners 2 11-06-2007 12:56 AM
Once again Exhaust Troubles! 94toyota4x4 86-95 Trucks & 4Runners 9 09-20-2006 07:22 AM
Engine Troubles 458 93-98 T100s 4 03-18-2006 02:01 PM
CB troubles... Stegall984R 95.5-2004 Tacomas & 96-2002 4Runners 0 02-11-2005 09:48 AM
2009 InternetBrands, Inc.
