PLease help...94 diff in a 90??
Old Nov 24, 2007 | 09:02 PM
pyro926's Avatar
My 1990 rear end just died. does anyone know if a rear end from a 94 fit? Anyone know what years will fit?
any help would be great,
Thanks
Old Nov 24, 2007 | 09:04 PM
seafarinman's Avatar
All of the 8" differentials from 79-95 will fit back there. Just need to make sure that the flange matches up.
Old Nov 24, 2007 | 10:10 PM
pyro926's Avatar
little more help please...
Is the gear ratio the same? and what flange are you talking about....
me <-------noob
thanks
Old Nov 25, 2007 | 12:13 AM
fork's Avatar
the flange is the part that bolts up to the driveshaft.
there are a few ways to figure out the gear ratio.
-check the axle code
-spin the tire, count the flange rotations
-pull the diff and count the teeth
Old Nov 25, 2007 | 09:54 AM
notanymore's Avatar
more info on the vehicles would help out but http://www.brian894x4.com/Gearratiosanddiffs.html should help you figure out what your ratio is now and you should ask what the 94s ratio is and if they are the same you should have no problems
Old Nov 25, 2007 | 10:02 AM
tc's Avatar
tc
http://home.4x4wire.com/erik/diffs/
Any front or rear diff out of a 85 or earlier
Any rear diff out of a 95 or earlier TRUCK
Any rear diff out of a 2001 or earlier 4RUNNER
Any elocker diff out of a 2004 or earlier TRD Tacoma (with modifications to your housing)
Essentially, the only things that WON'T work are T100, Tundra, and non-elocker Tacomas
live4soccer7
May 11, 2016 06:52 PM
Badlander
Oct 10, 2015 08:05 PM
Odin
Sep 26, 2015 06:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
zz_denis
Sep 6, 2015 03:43 PM
