Picked up a ticking, guzzling, no EGRing truck
Old 09-08-2009, 06:21 AM
aerocorey's Avatar
I just got my second Yota truck. The first was an 86. She's gone now. Now I'm buying a '94 with a 3.0 from a friend. He blew the head gasket on the driver's side about a year ago. He had a shop fix it. They decked the driver's side head and replaced both head gaskets. Now the CEL is on and the gas mileage sucks. It's throwing a 71. I've read a few people say they had bad modulating valves after blowing head gaskets, and I think mine is bad. It's getting vacuum, but that vacuum isn't getting to the EGR valve. The EGR valve passes the ol' suck & stall test. I'm not so sure the EGR accounts for the abysmal gas mileage. It's lifted with 33" tires, but I drive it gently, 55 MPH, 30 minute commute with only 2 stops. I think I'm only getting like 10 MPG. I'd expect to see at least 15 MPG under the gently conditions I drive, even with the tires. Should I check timing?
Old 09-08-2009, 07:04 AM
thadlinkwent's Avatar
Is it manual or auto?
Well part of your gas mileage is prolly due to the 33's. Wat gears are in the rear? You might need to upgrade in order to compensate for them. If you do a search it'll list a lot of info on it.
Old 09-08-2009, 08:07 AM
TNRabbit's Avatar
How's the idle?
Could be many things. I'd start with the EGR and fix that, then go from there.
Old 09-08-2009, 02:34 PM
aerocorey's Avatar
Says in the sig...it's a 5 speed. PO says he noticed a drop in mileage. I may regear, but I'm leaning toward going to a smaller tire.
Old 09-08-2009, 02:54 PM
yoterr's Avatar
well if you look hard enough (junkyards n such) you might find a set of 4.88 thirds, just a bolt on and thats about stock gearing for 33's and a 5spd, their found in 3.0 auto's with stock 31" tires theres a way to tell from the vin, thats around here somewhere....
Old 09-08-2009, 03:07 PM
G144 ... The guys around here take the rear diff and leave the front one.
Old 09-08-2009, 03:13 PM
rngrchad's Avatar
Hey man, it may have some problems but at least its NOT a 4runner.
LOL
Ichneumon
09-27-2015 04:21 PM
bigblue82
10
07-06-2015 08:27 AM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
greenmachine93
06-25-2015 07:50 PM
saphirekosmos
06-22-2015 10:26 AM
Quick Reply: Picked up a ticking, guzzling, no EGRing truck
