Odd Cooling Problem
Old 01-05-2010, 09:31 AM
Derek_SR5's Avatar
Odd Cooling Problem
My 1995 3.0 was cooling fine, or maybe a bit too fine, because the temp gauge would barely come off of full cold.
I decided to have my cooling system flushed and had them install a new t-stat (stant). I drove it on short trips (5-10 min) for a few days and the temp came up to the middle and stayed.
I took it out on the highway on Sunday, got about 20 miles down the road and the thing started to overheat. The air temp was -2 F on that day. They checked the t-stat and said it is opening fine, and they now suspect the water pump.
It just seems strange that it worked fine before the t-stat change, then the first trip of more than 10 minutes, it starts to overheat.
Any ideas?
Old 01-05-2010, 09:38 AM
yoterr's Avatar
odd how stuff works like that, soon as you mess with it to make it better it breaks, i think most water pumps have whats called a wheep hole, and when the pump isnt flowing right, it weeps out of this hole, i would also suspect the water pump if it was -2
the1998sr5
15
07-14-2020 08:35 PM
terminator
07-27-2015 07:13 PM
jackiebrownia
07-20-2015 09:02 AM
kyletbert
07-17-2015 11:39 AM
Avenged
07-09-2015 07:55 AM
Quick Reply: Odd Cooling Problem
