no rear brakes?
Old 09-17-2007, 07:00 AM
nick325i's Avatar
Question no rear brakes?
It doesn't seem like my rear brakes are working. Could the proportioning valve be bad (if it even has one, I know most car with disc/drum combos do have one) or maybe the master cylinder or line? I have tried bleeding them and I barely get any fluid out of the rear. Thanks for y'all's help...again.
Old 09-17-2007, 07:53 AM
Jay351's Avatar
Did you adjust the rear brakes?
Old 09-17-2007, 12:55 PM
nick325i's Avatar
Cool, I did a search on it. I'll see if adjusting it gets it fixed.
Old 09-17-2007, 02:00 PM
the_supernerd's Avatar
If the rear is not bleeding, then an adjustment will not help. What are you using to bleed the brakes? I have not had a lot of luck with the vacuum pump kind. Use either a power bleeder or traditional pedal pumping method. You might have a clog or possibly the master cylinder is filled with air and will have to be bench bled.
Flying91
45
04-11-2024 04:39 PM
06-01-2021 01:51 PM
rondogracing
07-14-2015 07:00 PM
87turboPA
07-12-2015 07:49 AM
87turboPA
07-09-2015 05:58 AM
Quick Reply: no rear brakes?
