New starter went up in smoke
Old 02-05-2007, 04:28 AM
fr0mh311's Avatar
Question New starter went up in smoke
Hello all, I have a 1986 Toyota pickup 4X4. The starter went over the weekend so I bought a new one and put it in. The new starter worked great the truck started right up no problems. I let the truck run for 20 minutes to heat up and when I went to get in it I noticed smoke coming from under the hood. After turning off the truck and checking for where the smoke was coming from I touched the starter and nearly cooked my fingers. Now I know where the smoke was coming from and I have 3 burnt fingers... What would cause the starter to cook like that? Thanks for any help.
Jon
Old 02-05-2007, 05:38 AM
MMA_Alex's Avatar
a short from a bad reman job? Where'd you get it from?
Old 02-05-2007, 06:41 AM
bob200587's Avatar
yea, something had to be wrong with it. It sounds like it must have never retracted and the flywheel was turning the starter gears. I don't think just electric current could have gotten it that hot. Then again, it might have. Either way I doubt it was your fault since there's only 2 wires to hook up.
Old 02-05-2007, 09:45 AM
fr0mh311's Avatar
Took that starter out, man that thing was fried. Took the power wire and terminal with it when it cooked, aswell. Now I just have to wait for the new one to come in tomorrow. Is there anything else I should check for damage?
Thanks,
Jon
Old 02-05-2007, 10:25 AM
MMA_Alex's Avatar
I think theres a starter fuse. I'd check it to see if it might have blown.
Old 02-05-2007, 06:42 PM
jaysTOY's Avatar
It sounds like somehow the starter was on the whole time (starter switch?). As far as the flywheel turning the starter gears, starters have an over-running clutch that should prevent this problem. If the flywheel turned the starter gear, the starter motor itself wouldn't turn because of the clutch, which means neither the power wire or motor would heat up. The first set of gears in the starter gearbox would heat up but thats it.
I use Toyota gear reduction starters in my electric go kart, so I do have some experience with taking them apart and rebuilding them
By the way, this is a good document for learning about starter components and wiring systems: http://www.autoshop101.com/forms/h7.pdf
ladybugRC
458
08-21-2020 10:41 AM
puddlepirate
07-30-2016 06:29 PM
dzldust
7
10-06-2015 05:39 AM
bradahman
10-01-2015 09:24 AM
charlie_fong
09-27-2015 10:06 PM
Quick Reply: New starter went up in smoke
