need help
Old 05-09-2014, 01:38 PM
robertloften5487's Avatar
need help
I have a 1994 Toyota pickup 4cyl 4x4 just had trans built new clutch set installed I have a good clutch pedal feel but the truck won't move it will go into gear running and without the clutch pressed in so I know something isn't right I left the front drive shaft out while I was checking it you can put it in gear and roll it and it is engaged but as far as using the clutch and driving its not I'm thinking I might have put the clutch disk in wrong or something with the release bearing I'm not sure any help would be appreciated thanks
