Mysterious Black Box
#26
Location: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
there you go.......if one of the most prestigious members of this site is within pissing distance best balieve I will shake his hand personally. You cant disreguard perfection in your own backyard.
#27
#29
#32
Don't think so... If it were, when I turned the key the starter would still crank the engine, wouldn't it?
#33
Know any good metal fabricators? I need some stairs, landing and handrail fabbed and hot-dip galvanized at our site, and need them within 2 weeks. Last guy I talked with wanted 7000 + the galvanizing for the stairs.
#35
Nah bud, no one that could do ish like that. Are you here for good, or just temp? I work off fields-ertle which is right off mason montgomery, your not working at 5191 Natorp Blvd by chance are you? If so that is the complex where I am at. There is a big Marriott across the street by Burger King and Wendys.
#38
Reverse is blowing fuse
New member here...I have a 92 4 Run-errrrrr with the 3.0 V6 engine. My Beast recently started to blow the instrumental panel 10 amp fuse. I have narrowed the problem down to what I believe is a relay switch of some sort when the transmission (standard) is placed into reverse. Any thoughts or ideas as to what is causing this and how to fix it?
#39
You'll get more interest and replies when you start your own thread.
#40
