Miss at constant acceleration
86 4runner 22re engine miss and interior ?'s
My 86 22re has a noticable miss at constant acceleration. I can give it gas and it will stop, but it's most obvious in 2nd and 3rd at lower rpms. It's got new plugs, wires, cap, and fuel filter. Any help with this would be appreciated.
Also, my interior is a little rough. The seats aren't terrible, but I don't have a carpet kit in it and the panels in the rear have seen better days. Is there somewhere online that I can get interior parts? Also, due to having no carpet kit, it is really loud inside while driving. I know I can't be the only one with this problem. What have you guys done to make your interior nice and quiet? I'm considering rhinolining the interior, would this cut down on noise?
Again, any help would be much appreciated.
remove all the plastic panel, rhino line everything, recover the seats in vinyl. Then when you get back from the trails you can just hose everything off and you also don't have to worry about ruining your new carpet if that mud hole ends up being a shade deeper than you thought it was...
as for your miss, i'd start by hitting it with a timing light and make sure you're on time. Could be a ton of different things, but i'd start with the basics.
thanks for the info guys. i'll do some research on how to check grounds and tps and let you know if that fixes it.
junkers88...it's white body, black topper with a great interior. one of these days i'll get a pic up in my profile
crammit442
7
11-29-2017 12:30 PM
88runnergomas
07-09-2015 01:12 PM
