Lock Out swap
Old 04-01-2007, 01:52 PM
Duelertoyota4x4's Avatar
Lock Out swap
I have an 86 runner with automatic hubs. I got a deal on a P/U of the same year but it has manual hubs. I would like to swap them out and put the manuals on my runner. My question is this...is it a direct bolt on? Do I have to change spindle/knuckle and all? I know I will figure out when I get ready to do it but I figured a little insight before I start will couldnt hurt. Thank you for any input you might have.
Old 04-01-2007, 02:17 PM
Staff
DeathCougar's Avatar
not a direct bolt on. have to change the guts of the spindle, mainly the outer hub retaining nut etc.
Old 04-01-2007, 05:13 PM
leebee's Avatar
it should be a direct swap over, i dont have access to the online service manual to give you the link. someone will probably post it up for you.
lee
Old 04-01-2007, 05:39 PM
Staff
Its NOT A DIRECT SWAP
Its only a direct swap if has ADD, which did not start until 1989. AUTO hubs use a different setup on the outer edge of the hub, ie different nuts, and guts of the spindle. That has to be switched out before you can install the manual hubs.
Old 04-01-2007, 11:18 PM
Staff
btw, try this link:
http://www.wabfab.org/aisinmanualhubs/aisin.htm
Wabbit has all the parts you need to do this swap.
Old 04-02-2007, 03:57 PM
I have everything from the donor truck....hubs...bearings....nutst thrustwashers....everything that your link shows....so it should be a direct swap over if im reading that correctly.
Old 04-03-2007, 06:03 PM
yep it was....easy peesy japaneesy....thank god for 100 dollar donor trucks.
deepmarsh
08-06-2015 03:44 AM
jaretstuff
08-04-2015 02:08 PM
MTLroadierunner
07-20-2015 03:07 PM
PlayAwhile
07-20-2015 11:36 AM
AaronM
07-08-2015 07:15 PM
Quick Reply: Lock Out swap
