lighting for snow
I know that many won't agree, and it may be out of your price range, but I did an HID projector conversion in my headlights and they do great in the snow. When running the low beams there is zero light above the cutoff, so you don't just see the snow falling in front of you. Plus the light spread is very even and wide. I get about 6800 lumens from two lights that run at 35 watts! Really, the only downside is the cost, IMO
Infrared is different than thermal imaging; just a heads up.
How? Infrared in the spectral range pics up a heat signature. So is it that different? Yes there are sensors that are tuned to thermal spectra and so they will be better at detecting a dialed in heat signature, but Infrared can do this job if you are looking for a heat signature in the infrared range.
"Infrared radiation has wavelengths between about 750 nm and 1 mm, spanning three orders of magnitude. Humans at normal body temperature can radiate at a wavelength of 10 microns.[1]
Infrared imaging is used extensively for both military and civilian purposes. Military applications include target acquisition, surveillance, night vision, homing and tracking. Non-military uses include thermal efficiency analysis, remote temperature sensing..."
Just sayin' Then again I might be splitting angstroms....
And now back to our regularly scheduled light discussion....
#25
So now let me shell out... I was suggesting... in spite of the apparent confusion regarding thermal and infrared imaging... where the camera has an infrared source of a particular wavelength and the camera has a detector tuned for that wavelength thus allowing the camera to resolve terrain and other errata without concern for the... um... temperature of said errata or terrain, as I alluded to earlier with reference to 'night vision'. Night vision goggles do not rely on temperature alone but also use an illumination source to which the goggles are sensitive to the reflections of.
The point is that passive infrared imaging relies on residual heat, but active thermal imaging does not and supplies an illumination source sympathetic to the receiving imaging apparatus most sensitive wavelengths.
#28
Molly, you are 100% correct that both types of imaging are technically infrared but; in the vernacular one type is referred to as Night Vision or just Infrared & another type is referred to as Thermal Imaging. Getting into wave lengths, illuminators, lens types, the electronic filtering used etc. we could discuss in lengthy paragraphs for a while.
Here are a couple examples of different types of Thermal Imaging
Here are a couple examples of infrared or "night vision" (common vernacular)
#29
We've had good luck with Hella H4 (e-code) lamps in almost all conditions. We do a fair bit of high-speed driving in the winter when we go skiing. Just don't use the high beams in the snow, or all you will see is incoming snow.
I know that e-code lighting is perfectly legal in Canada, but may not be in all states. The Hella part number is 72200 for the 6054 rectangular replacement lamps.
Im going this route once I get some extra green to spend on whatever. Where did you order yours from? I lost my contact in the us so shipping is a pain in the arse again!
#30
If you want to go really high-tech you need to combine the imaging from the night-vision canera with a forward radar system to give you accurate information on distance to objects in your path since with a single camera forward you loose the depth of field info you get from stereoscopic [normal] human vision. you could rig up a dual camera system and run it through seperate HUD displays for each eye but now we are getting a little nuts...
#31
#32
Driving with Night Vision sucks, especially in snow. I drove a few convoys when stationed in Alaska and upstate New York. Night vision offers no depth perception. I have seen guys on point walk off banks. The green tint sucks and is grainy.
Thermal (see FLIR systems) would show every hotspot on vehicles--exhaust, brakes, engine etc etc. Though a PAS-13 works great for hitting a guy at 300M in a snow storm with an M-4
To the OP I had good luck with Yellow lenses in the snow. Sounds like the Light Force lights would be a good investment.
djpg2000
11-11-2020 04:56 AM
FS[PacNorWest]: Toyota Inclinometer/Altimeter
AkitaDog
09-01-2015 08:05 AM
PopsDad1
07-30-2015 02:21 PM
