Left cv boot
Old 05-14-2008, 04:33 PM
crews462's Avatar
Left cv boot
Hey, got somewhat of an easy question, could use some feedback.
Got an 89 Pickup 22RE, The left cv boot clamp is loose and leaking, the boot isn't ripped, is it worth it to repack the boot and replace the clamp? Or should I just put in a new shaft. Just put in a new right cv shaft and it's pretty simple, I'm just thinking of cost and reliability. Thanks
Old 05-14-2008, 04:49 PM
rdlsz24's Avatar
If you just put in a new right axle I would put a new left in to match. You can't go having mismatched axles now
Rob
Old 05-14-2008, 04:56 PM
abecedarian's Avatar
Clean the joint up and check the bearings and races to make sure there's no pitting. If everything's good, repack and seal it up. Boots aren't that expensive so it may be a good idea to replace it anyways.
IntoTheVoid
10-24-2015 04:54 PM
Scatterbrain
09-27-2015 08:24 AM
PBRaddict#1
09-22-2015 07:50 AM
user 82300
09-22-2015 07:00 AM
pickle6415
09-10-2015 10:57 AM
Quick Reply: Left cv boot
