knock sensor issue
Old Dec 15, 2007 | 12:15 PM
skife's Avatar
knock sensor issue
i just swapped out a seized 85+ 22RE for an pre 84' 22r block, i put my EFI stuff on the block, except there is no place for the knock sensor in the block.
what should i do? will this mess with anything leaving it unplugged?
Old Dec 15, 2007 | 12:17 PM
fillsrunner4's Avatar
I dont think the knock sensor will keep it from running. you have a code using your comp but i dont think it will keep it from not running. Im not 100% sure on this so dont hold me to it
Old Dec 17, 2007 | 05:48 AM
de6w6it's Avatar
the knock sensor just advances or retards timing when it senses knocking. i have heard of that sensor affecting mileage if it is not changing the timing correcctly. There are other things the ecu uses to control the timing, I would just try and figure out how the knock sensor sends a signal to the ecu, and try and mimick it, if you don't want to get the code.
montanatruck
Feb 26, 2017 07:07 AM
nonstop
Jul 24, 2015 06:29 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
keithporter83
Jul 18, 2015 12:37 PM
smiley52
Jul 11, 2015 05:16 AM
