Knock sensor CONNECTOR location?
Got a code 52, STILL!
Thought I found a bad wire, redid it, but it wasn't the knock, it was the oil pressure wire, yellow/green wire.
Trying to find the knock sensor location. From under the vehicle, above the oil pressure sensor there's a plug...IS THAT IT?
On the 22re do you have to take off the intake to get to it, or can you get to it without doing that?
I believe it's a black/dark gray wire? Right?
I've searched this whole site and the web to try to figure this out. The code 52 started just after I took out my airbox and put in a cone, and moved my battery to the drivers side, so I'm thinking I just hit something.
Thanks!
Thanks!
Tacoma1313
08-17-2015 05:44 PM
88yodabasket
07-13-2015 01:32 PM
