just replaced clutch...problem
Old 01-17-2008, 07:37 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Was the tranny working fine before the clutch replacement? If so, I seriously doubt that's the problem.
You can check the clutch pedal height and push rod freeplay with this:
http://personal.utulsa.edu/~nathan-b...sm/clutch.html
IF all that checks out fine and you're sure the air is all out, something went wrong in the installation. There's not that much to a clutch assembly to go wrong.
Did you replace the shifter seat bushing and end cap?
Old 01-17-2008, 10:00 AM
nate V's Avatar
Sounds like tyranny to me as well
if not did you replace either the slave or the master with out replacing the other.
happened to me once. they need to be replaced together or else the displacement is not equil and will not work.
Is the problem the same as b4 when you decided to replace the clutch???
Old 01-17-2008, 05:49 PM
89yota_mudrunner's Avatar
i didnt replace the slave or master cyl. i just bled the hydraulic line. now it goes into gear and when i go down the road it has a hard time shifting. it will shift but i have to really jam on it to get it into gear. my mechanic is a few miles down the road so it will make it there this weekend. but ya the tranny worked fine before the clutch went in and the clutch went in right.
Old 01-17-2008, 05:58 PM
89silverpu's Avatar
I didn't have to bleed anything when I changed my clutch....
Old 01-17-2008, 11:49 PM
  #25
thook's Avatar
Shifter seat bushing? Did you replace it? Did you get the shifter back in correctly?
Old 01-18-2008, 02:03 AM
  #26
sleepy970's Avatar
You know I had a similar problem some years ago in a 96 GMC Jimmy with manuel trans. When I would start it and that it would move with the clutch engaged and was very hard to shift it. Once the trans got nice and warm it started to shift fine down the road. The trans fluid was low in it so filled it up and that fixed my problem. I don't know if it will help you any, but it might.
Old 01-18-2008, 02:26 AM
  #27
TNRabbit's Avatar
That doesn't make any sense from a physics standpoint. What would transmission fluid have to do with the clutch?
Old 01-18-2008, 03:49 AM
  #28
sleepy970's Avatar
To be honest I know it doesn't make sense but for some reason it worked.
I was getting out of my college class went out to my Jimmy the clutch was working right but got home and still doing it filled the trans and it worked fine after that. Maybe there were some gremlins messin with me that day
Old 01-18-2008, 06:30 AM
  #29
ya the shifter is in correctly. im gonna replace the slave cyl today. what happens when you replace the slave cyl without replacing the clutch master cyl?
Old 01-18-2008, 06:41 AM
  #30
TNRabbit's Avatar
If one or the other is bad, you just need to replace the bad one.
Old 01-18-2008, 08:00 AM
  #31
thook's Avatar
Nothing, if the master cylinder is good. If not, the MC will naturally go out on it's own accord. The only reason these things go out is because folks tend to neglecting keeping the clutch fluid fresh and flushing the lines. Water builds up and the metals and seals corrode.
mskalmus
05-28-2017 07:51 AM
TURBOrunnerNM
07-22-2015 11:01 AM
rushw
07-18-2015 01:46 PM
1994toyota
07-17-2015 03:03 AM
redghost.308
California SoCal
07-16-2015 07:46 AM
Quick Reply: just replaced clutch...problem
