jrrtt09's build up of Clay
Old 02-28-2014, 08:21 AM
jrrtt09's Avatar
I've decided to make one thread for the rest of my build. So far, I have ball joint spacers up front, 7" shackles in rear, and 4.88 gears; the install is in the thread below.
https://www.yotatech.com/forums/f116...pickup-255628/
Old 02-28-2014, 09:17 AM
Jbowls's Avatar
Nice job on the bed.
Old 04-28-2014, 07:48 AM
jrrtt09's Avatar
TC Lower Uni-Ball?
I've brought my truck to 3 different alignment shops, and they haven't been able to get it correctly aligned, my right tire is pushed out all the way and my right tire is pulled in all the way. The frame was bent when I got the truck, a shop pulled it straight, but I'm not so sure if it's straight any more. I have quite a bit of slack in my steering now and I plan on replacing ball joints, tie rod ends, pitman arm, and idler arm (adding brace also). I may also replace a-arm bushings.
Kolton5543
01-16-2019 05:30 AM
andlours
07-23-2012 06:05 AM
wilson109
05-13-2012 10:00 AM
mach4
19
01-05-2006 05:28 AM
Ilovemountains
12
08-30-2004 05:52 AM
Quick Reply: jrrtt09's build up of Clay
