I'm goin' in! - 3.0 Head Gasket -tips/tricks welcome
#41
FOUND THE THREAD!!!!!!!!!!!
I was all mixed up on this one. It was posted by Weasy2k in 2k7.
https://www.yotatech.com/forums/f116...notice-118381/
#43
Really? And, why is that? Like zlathim said, how do expect to check them? They've been tighten twice down past the initial torque spec. Plus, they are not coming loose. If you did it right the first time...and you should.....a 500mi/1000k mi/or whatever mile inspection is just not necessary.
#44
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
My bad, I didn't mean to say to re-torque them, what I meant to say was to check the torque load and compare them to the torque numbers from the final sequencing(sp?), after the additional 90 degrees. I totally mistyped and didn't re-read what I typed before I posted.
#46
Well, a little extreme, but you make a good point, zlathim. These are torque to yield headbolts. They are not designed to require retorqueing. In fact, I dare anyone to do it. It's so much fun trying to remove one of them suckers when they snap...and they can and do when stretched beyond their limit. I've been through it.
Advising someone to retorque them is simply unwise and uneducated....as good as the intentions may be. If anyone should have doubts regarding this, there's ample info on the web about how TTY HB's are designed.
Errrrr- Uhhhhh, well, buut, errr---ah heck with it, never mind.
#47
You're welcome, zlathim. It was just bugging me to post something vague without better explanation. I just had to let it go so the memory would come back.
And, hey.....we all have our moments.
#48
I did this rebuild when I had a 3.0. Not too bad, just time consuming, not too much space to work with. I would recommend pulling the engine for the rebuild, unless you are just doing the top end. Definitely check your valves and replace if necessary. And spend the money on getting the head resurfaced, it'll save you from having to do it all over again...
#49
the best trick I learned that I've not heard on here - once you've installed the new injector O rings, injectors, fuel rails, fuel pipes and fuel regulator...kick the fuel pump on to see if it leaks! I had my plenum back on only to find that 3 of the 6 new O rings failed even after dipping them in gas before the install.
To engage the fuel pump - turn the key on the in the diagnostic port jump the P and the FP terminals. They will be the two corner terminals located closes to the passenger side firewall.
kgcwb44
01-29-2023 10:02 AM
the1998sr5
15
07-14-2020 08:35 PM
09-04-2015 09:27 AM
