Idle Issue - Page 2 - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-16-2007, 06:05 PM   #26 (permalink)
JEBSR5's Avatar
Quote:
Originally Posted by rdharper View Post
Two more thoughts. The codes don't always point you in the right direction... in fact that is understating it. This is partly because something can cause a problem which the ECM tries to compensate for, causing something else to "code".
Also, if it is the AFM, it will get worse with time, finally to the point where you are lucky to get it through an intersection when the problem shows up.
Thought you said you moved the plate. If so, that would have moved the pickup from the discontinous point (if there is one). So next time you get a no-start, try that again, as it is relatively easy to do. Also, you may notice hiccups while driving from the same problem... which would get more common with time. So that is my experience with the AFM.
In my own case, when I was finally convinced it was the AFM, I dug out the RTV and lifted the black rubber plate on top. Once that was off, it was obvious what the problem was. The resistive plate the contact slides on as the gate moves, had a groove worn in it. So, as I said, if that is the problem, you will have lots of further head-scratching opportunities. If the problem doesn't change, then you can figure its something else.
I could not fix the internal plate, although I tried, finally paying full retail to make sure I got a new one, as it was clear they wear out. In the case of the '85, there was 200k on it. So they last a long time (one way to look at it).
Already have that idea in mind to move the AFM flapper first if it does that again. Really runs great now when it's running. Smooth, no hesitation, rarely hear a spark knock.
I'll wait and see before digging into AFM lid.
__________________
90 4R SR5 4WD 5SPD
3VZE
211K miles
'69 Ford Mustang Mach I
'82 Suzuki GS1100E
'68 Chevelle SS396
'99 1/2 Pathfinder LE
JEBSR5 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Idle issue Sonofmayhem 86-95 Trucks & 4Runners 40 02-05-2007 06:50 PM
22RE Idle Issue blb 95.5-2004 Tacomas & 96-2002 4Runners 5 01-02-2006 02:32 PM
22RE idle issue? dave151 95.5-2004 Tacomas & 96-2002 4Runners 3 10-24-2005 12:48 PM
idle issue jayson161 95.5-2004 Tacomas & 96-2002 4Runners 5 12-13-2004 08:57 PM
Idle spped issue markjs 95.5-2004 Tacomas & 96-2002 4Runners 8 01-03-2004 02:32 AM
2009 InternetBrands, Inc.
