I need help finding parts for my truck
Old 05-05-2010, 09:58 AM
TimtheMaggot's Avatar
these are pic of my engine compartment and i need help from yall to tell me what im missing the truck is a 86 sr5 extra cab 22re motor and five speed 4x4 tranny
all help is very much appreciated
Old 05-05-2010, 10:13 AM
yayfortrees's Avatar
Instead of attaching the photos, try inserting them into the message. That's a lot of pictures for people to have to click on, in order to help you.
You would probably be better off using a factory service manual (FSM) to determine what you need. You are the best person to determine what you need, since none of us are actually there.
Good luck and welcome to YT.
Old 05-05-2010, 10:25 AM
waskillywabbit's Avatar
You need a professional Toyota mechanic.
Old 05-05-2010, 10:28 AM
snobdds's Avatar
Just get a used junk yard engine. It will be cheaper in the long run rather then buying individual parts.
Old 05-05-2010, 12:55 PM
iamsuperbleeder's Avatar
OMG dewd! Rusty valve-train!
you better get you a donor vehicle from a junk yard I wouln't run ANY of that top-end
that thing looks like it's been sitting in a junkyard itself, and random parts (more spefically the upper intake and valve cover) have been robber from it...
Old 05-05-2010, 02:59 PM
LITLRED's Avatar
I don't see a wiring harness. When you replace the engine try to get one that includes the harness so they are compatible. You have quite a project on your hands.
Old 05-05-2010, 03:52 PM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
agree. And or a parts truck...
Find a runner that was rolled or in a wreck, etc...
Old 05-05-2010, 03:59 PM
sooo, just as a challenge, anyone going to make a list of what looks like is missing, or am I going to have to do that
Old 05-05-2010, 04:04 PM
calcuta's Avatar
iF THE TOP END OF IT LOOKS THAT RUSTY THE BOTTOM END IS JUST AS BAD EVEN WITH ALL THE PARTS IT MOST LIKELY WON`T RUN LONG IF AT ALL
Old 05-05-2010, 04:08 PM
Teuf's Avatar
I think the spark plug on # 4 is loose? Could be wrong, have been B4.
Old 05-05-2010, 05:10 PM
awe man... I had a good one lined up then the internet went out
isn't caps lock fun?
Old 05-05-2010, 05:38 PM
Toyota Pete's Avatar
I would have to agree with some of the others and suggest finding a donor vehicle. Even the timing chain sprocket is broken. There could be a lot of internal engine damage. Where are you at? I have a lot of parts and a good short block etc.
Old 05-05-2010, 06:51 PM
RustBucket's Avatar
Well you certainly have enough pine needles... don't need to order any more of those.
Old 05-05-2010, 07:27 PM
ACZR
06-23-2015 07:55 PM
Chooch
06-19-2015 03:05 PM
streetuner15
06-18-2015 10:59 PM
Mutinebullfrog
06-18-2015 01:36 PM
Quick Reply: I need help finding parts for my truck
