I dont change my oil...good or bad thing?
Old 09-12-2007, 11:39 AM
4rnr's Avatar
My 88 4runner 3.0 leaks about 1 qt/ 2-3weeks. I put a ton of mile on it!
I just keep topping it off with my mobil 1 synthetic, and I replace the oil filter about every 10k miles....thoughts??
Old 09-12-2007, 11:42 AM
keithguts's Avatar
Well 1st off, I would look into getting that leak fixed. with a 3.0, I would still change it every 5K if I were you. Also might want to go to dino oil as syth may be making you leak more the it has to.
Old 09-12-2007, 11:46 AM
4rnr's Avatar
Fix the leak? meh. it keeps the front of my truck from rusting.
Dino oil? Ive thought about it but my other trucks all run M1 syn, and its just nicer stocking up on 1 kind of oil.
Old 09-12-2007, 11:51 AM
keithguts's Avatar
Well, I got to say, , but so do you.
Old 09-12-2007, 11:57 AM
michalik_piotr's Avatar
mobil full synth is expansive! if you're leaking/burning that much....i'd just buy reg oil, and a thicker one too....burns/leaks out less/slower.
Old 09-12-2007, 12:08 PM
ozziesironmanoffroad's Avatar
just dont go hardcore with heavy oil. i tried 30w, and for awhile it was good, wasnt burning or anything. but it started affecting my truck, it was getting horrible gas mileage, i could hear rattling in the engine like, really bad. when i heard that i immediatly changed oil to 20w-50. no problems. except that kragen(checker) gave me the wrong PCV valve and im burning oil like crazy. friggin checker! im gonna have to go to the stealership anyway... (thermostat)
Old 09-12-2007, 01:17 PM
tc
tc's Avatar
Wait, you spend like $10 every 2-3 weeks burning M1 synthetic? :eek:
I wish I had that kinda money...
Old 09-12-2007, 01:24 PM
4rnr's Avatar
$6
10w30
Old 09-12-2007, 01:31 PM
sdstud212001's Avatar
Just mix ur oil with gorilla glue that should fix that leak.
Old 09-12-2007, 01:36 PM
gorilla glue? does that actually work???? it sounds pretty BAD.... im not sure id want gorilla in my engine.... in any amount....
Old 09-12-2007, 01:42 PM
tc
tc's Avatar
That's still like $150/yr! That's a week of hotel stay in Moab during the offseason!
Old 09-12-2007, 01:56 PM
infiltrator's Avatar
yeah, i posted a thing on here about changing my oil over to synthetic. apparently, many people have had more leakage when doing this...
yeah, listen to them, switch back to dino juice man, try 20w50 that is what i use and i get some leakage, but not that much... and its better on the freeway.
try it.
Old 09-12-2007, 01:59 PM
RustBucket's Avatar
I think that if you neglect to actually drain the pan from time to time you could get a buildup of sludge and stuff. Probably should at least drain the pan when you do the filter.
Old 09-12-2007, 02:14 PM
86tuning's Avatar
Yup.
weekly top up of 10w30 synth isn't going to hurt anything. At 10k, I'd drain the pan at the same time the filter is done.
Changing front seals is pretty simple, and if your t-belt is getting soaked in oil, it's gonna fail. When it does, tow it home, and do it all: t-belt, waterpump, bearings, and 3 front seals. That should reduce your oil leakage, as the only other seal is the rear main, then the v/c and oilpan gaskets of course...
Old 09-12-2007, 02:53 PM
4rnr's Avatar
Draining my pan every 10k would constitute an oil change Though I did give thought to what would happen if I never drained the pan...
I may switch to a different oil if I get around to it, but again that would constitute an oil change. I do a slick 50 every once in a while, so maybe ill switch to a cheap to penzoil cheap dino oil.
My leak is likely valve covers its not the front seals. I know that for sure.
I know a syn will make an existing leak leak more.
I run a thinner oil bc I live in chicago, not california.
Old 09-12-2007, 02:57 PM
Shoretaco's Avatar
Why wouldn't you fix the leak. Ive seen guys run the beaches of NJ with Oil leaks it drives me crazy. I just don't get it anymore, nobody cares. No one says please, thank you, excuse me, what the heck is up. People throw trash out their windows. You should fix the leak just to make me feel better.
Old 09-12-2007, 03:00 PM
87TurboYota's Avatar
Just curious how long have you been doing this? If anything you could consider switching weights just to save yourself a little money.
Old 09-12-2007, 03:08 PM
Jay351's Avatar
I would at least change your filter more often, at least around 5K
I change my oil every 3500kms just to be safe
Old 09-12-2007, 03:28 PM
i change oil and filter every 3000
CyMoN's Avatar
I ran a 83 Honda civic for 4 years without ever changing the oil and only changing the filter 2 times,
I just added oil ever week and I put over 50k miles on it sold it to some one else and they had it for 8 more years before they got something else.
my ford I did the same I would just add more oil every week with it I kind of wanted to see if the motor would mess up but it did not.
but both of those vehicles I did not care for with my Toyota's I try to change the oil at least every 4k. I hate seeing dark sooty oil on the dipstick.
Quick Reply: I dont change my oil...good or bad thing?
