Hypoid tranny/xfr case oil, or no?
Old 08-27-2006, 01:55 PM
Keggo's Avatar
I'm getting ready to change out all the fluids in my truck. I have a V6, manual tranny, VF1A xfr case, 4wd... Here's how the service manual reads for my truck's specs...
FLUID CAPACITIES TABLE
Application (1) Quantity
Crankcase (Includes Filter) ........................ 4.8 Qts. (4.5L)
Cooling System (Includes Heater)
A/T ............................................. 10.4 Qts. (9.8L)
M/T ............................................ 10.6 Qts. (10.0L)
Manual Trans. (SAE 75W-90/API GL-5) ................ 3.2 Qts. (3.0L)
Automatic Transmission (Dexron-II)
2WD
Dry Refill ..................................... 7.6 Qts. (7.2L)
Drain & Refill ................................. 1.7 Qts. (1.6L)
4WD
Dry Refill ................................... 10.9 Qts. (10.3L)
Drain & Refill ................................. 4.8 Qts. (4.5L)
Differential
2WD (SAE 80W-90/API GL-5) ........................ 1.9 Qts. (1.8L)
4WD
Front Axle
With ADD (2) (SAE 75W-90/API GL-5) ........... 2.0 Qts. (1.9L)
Without ADD (2) (SAE 80W-90/API GL-5) ........ 1.7 Qts. (1.6L)
Rear (SAE 80W-90/API GL-5) ..................... 2.3 Qts. (2.2L)
Transfer Case
A/T (Dexron-II) .......................... .8 Qt. (0.7L)
M/T (SAE 75W-90/API GL-5) .............. 1.2 Qts. (1.1L)
(1) - Approximate quantity listed.
(2) - Automatic Disconnecting Differential (ADD).
If you look at it... the tranny and transfer case say to use 75W-90... Does that mean, I could just use standard 75W-90 and not have to use Hypoid (or GL-5)? Thanks!
Old 08-27-2006, 05:54 PM
tc
tc's Avatar
http://www.4crawler.com/4x4/index.sh...ntheticGearOil
calderp
Engine Swaps
08-16-2016 05:15 PM
calderp
07-27-2015 09:58 AM
89hilux1
07-19-2015 01:32 AM
crashburnoveride
07-10-2015 06:39 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: Hypoid tranny/xfr case oil, or no?
