hydrocarbons at 41.26 wth
Old 02-28-2011, 09:09 AM
shaunneuhaus95's Avatar
took the 94 runner for emmisions and my 3slow is pumping out 41.26 on the hydrocarbons which is double the allowed amount for arizona, im no expert on emmisions, but thats bad. any ideas or threads that could help me out on a good start point would be awsome.
Old 02-28-2011, 01:14 PM
runner126's Avatar
dump interested as well in how to go about solving the high HC level...failed california smog
just found this...not sure if it helps but ... http://www.smogtips.com/failed-high-hydrocarbons-HC.cfm
Old 02-28-2011, 01:22 PM
thanx im gonna read it tonight
Old 02-28-2011, 01:48 PM
James Woods's Avatar
You can look to some things as clues of what might be going on, has the MPG's gone down, engine running rough stumbling and misfiring, is the engine running too hot or too cold, any codes at all? Many things can cause high HC's from a bad cat to O2 sensors to a stuck open thermostat. I would start with checking for any codes and go from there.
Old 02-28-2011, 02:54 PM
total quick version 2 years ago i blew hgs and it sat in garage. 3 weeks ago it went to toyota to replace hgs. now 246 miles since i got it back. i havnt noticed gas miledge going down. engine runs smooth but i feel that it runs a little hot, no cel new o2 i have a new cat not sure if i want to put it on yet. timing is advaned a bit. i thought all a cat does is drop the nox does it also drop hydrocarbons
Old 02-28-2011, 05:12 PM
Hydrocarbons are basically unburned fuel molecoles, and the cat does convert hydrocarbons along with carbon monoxide, and nitrogen oxides into less harmful gases. If it were my truck, I would put on the new cat, return timing to OEM and run some guarentee to pass stuff through my tank and then try again.
Mulkey
14
12-21-2016 05:17 AM
Fink
01-30-2010 03:40 PM
elnido
22
10-15-2009 05:24 PM
Quick Reply: hydrocarbons at 41.26 wth
