how loud do your valves tick on 22re?
Old 06-01-2008, 07:32 AM
kd
kd's Avatar
i adjusted my valves to spec but they seem a little loud. i bought the truck non-running so i have no baseline to start from. dosent sound horrible just a bit loud. is that normal? im going to re-adjust them after 100mi. or so
Old 06-01-2008, 07:45 AM
vmax84's Avatar
I'm sure one of the experts here will chime in, but I would lean towards a little loud vs. not loud. Or, to say another way, I would rather have the valves set a little on the loose vs. a little too tight. If they are too tight, which I would think would be a little quieter, they would hang open a little, which would lead to burning your valves.
Just my thoughts, whether right or wrong!!!
vmax84
Old 06-01-2008, 09:08 AM
My99's Avatar
Did you adjust them cold or warm and what settings did you use?
I adjusted mine (cold) when I rebuilt the engine a few weeks ago. They were noisy. I drove it like that for about 600 miles and then adjusted them "warm" this past Friday. The noise has totally gone away. I used .008 intake and .011 exhaust. I think the FSM says .012 for the exhaust.
Old 06-01-2008, 09:11 AM
dirtoyboy's Avatar
Are you sure its not your injectors ticking? They can be quite loud...which is good...means they are working
Old 06-01-2008, 09:36 AM
Beaniam's Avatar
Be sure you don't torque down the valve cover bolts too tight. That will cause louder ticking from over stressing parts. They really only need to be a little more than hand tight
Old 06-01-2008, 10:00 AM
Kaydon's Avatar
My truck sounded like a diesel at one point.
Old 06-01-2008, 05:21 PM
iamsuperbleeder's Avatar
X's 2 on the valve cover bolts; seen it twice now on the 22re; not on my truck, but friend's trucks
that's easy to check though; just losing the bolts while the trucks running. if it goes away, they were to tight...
montanatruck
02-26-2017 07:07 AM
09-04-2015 09:27 AM
PlayAwhile
07-20-2015 11:36 AM
cars-guy
07-11-2015 07:51 PM
Gamble_STi
07-07-2015 07:54 PM
Quick Reply: how loud do your valves tick on 22re?
