How to indentify the type of transmission ?
Old 11-15-2008, 09:29 AM
gixxer's Avatar
I have a 91 Toyota pickup 4x4 with 5 speed. I am in the process of replacing the clutch, and figured while I have the transmission down I want to replace the input shaft seal. What type of trans. do I have ?
When looking for a replacement seal, they ask if I have a WM trans, or GM trans., or RM trans.
I want to replace the front seal of the pinion on the transmision.
Old 11-15-2008, 09:35 AM
MSR
MSR's Avatar
4cyl or v6, add or manual hubs?
Old 11-15-2008, 09:40 AM
gixxer's Avatar
4cyl 22re manual hubs
Old 11-15-2008, 09:48 AM
Staff
DeathCougar's Avatar
W56, assuming your truck came from the factory with manual hubs and no-ADD.
You can also check the door jamb on the drivers side, it will have an information plate/sticker that will tell you codes for your Axles, Trans, Exterior Color, and Interior color
Old 11-15-2008, 09:55 AM
gixxer's Avatar
I didn't know about the transmission info on the plate, I have the W56 according to the plate, Thankyou for the info.
Is the input shaft seal the correct term , I want to replace the seal on the transmission front pinion that goes into the clutch ?
gyroscope7
7
09-27-2015 08:39 PM
Jwp1
09-06-2015 11:03 AM
Badfish740
09-04-2015 04:21 AM
kelly1450
09-02-2015 12:29 PM
Quick Reply: How to indentify the type of transmission ?
