Help with rear diff (ring and pinion)
Old 07-10-2014, 03:24 PM
mistyg7's Avatar
So I am rebuilding my rear on my 1991 Toyota pickup 4wd v6. The ring and pinion got delivered today and it is slightly the wrong ratio . The ones I took out were 4.1 and the new ring and pinion ratio is 4.3. Can anyone tell me if I could just use the 4.3 and if so what would be the difference or effects of doing so. I also put 31" tires on when I rebuilt the truck not sure if that matters or not. Any feed back would be great thanks!
Old 07-10-2014, 05:51 PM
Punchy's Avatar
Matters a lot, You will bind and blow parts, Send them back.
Old 07-10-2014, 05:56 PM
Fossilized
Staff
dropzone's Avatar
how did you determine it was the wrong ratio? Count the ring gear teeth and divide by the pinion teeth?
Punchy is correct...the f/r ratios need to be the same or you will bind like a .....
Old 07-10-2014, 06:54 PM
Yotard's Avatar
Gears absolutely have to match front to rear otherwise you will destroy your transfer case.
Old 07-10-2014, 07:10 PM
JasonYota's Avatar
I wouldn't say all that. It will bind up but it's only 4.10 and 4.30's. Long term, get matching gear ratios.
I've ran different gear ratios and/or different tire sizes front to back, binds like crazy buts never broke anything. This was using 4wd only when it was absolutely needed until proper gears and/or tire sizes could be matched.
Old 07-11-2014, 06:09 AM
mistyg7's Avatar
Thanks a lot I should have double checked counting the number of teeth when ordering. Got a new one on the way
the1998sr5
15
07-14-2020 08:35 PM
oldirtydirt
02-23-2020 09:30 AM
jerusry
10-19-2015 05:28 PM
Daneums
08-20-2015 05:36 AM
scottyg486
07-19-2015 05:34 PM
Quick Reply: Help with rear diff (ring and pinion)
