Help finding drain cock??
To be quite honest, and this comes from a matter of a different objective, but being Canadian, I don't like his replacing the maple leaf with a pot leaf. I find that offensive.
That said, I will not try and quash his right to freedom of speech. Even if it makes him look like a ****.
And your drain is located on the passenger side, on the back side (engine side) of your radiator.
The screen_name osamabinladen isn't about politics, its about a travesty to the American people. And, not to leave anyone out, he then chose an avatar that degrades the Canadian flag. Between the two countries, that makes up almost everybody on this board. I vote name/avatar change as a sign of forgiveness and a second chance.
#27
ok, so ABOUT THE TOPIC AT HAND
Jesus people leave it alone.
Are you talking about the BLOCK drain, or the radiator drain cock? If you have a factory radiator, it will be pass side lower down. Should be a wing nut shaped plastic plug. If its aftermarket, there will be any of 40 different designs for drain plug.
If you are talking about the block drain, i am not 100% sure where it is but it will be either side under the freeze plugs.
#28
http://personal.utulsa.edu/~nathan-b...08coolantc.pdf
and it indicates there are 3 drain plugs, however, I can not figure outwhere about the one that is located on th driver's side. Is it more near the front of the engine than the diagram indicates?
#32
#36
seriously if this guy gets to keep his name, i want Adolf Hitler, its only fair if you allow one person to pick such a vile human, than i should be allowed to pick from the bunch.
