help diagnose problem w/'91 truck
Old 02-25-2006, 12:36 PM
ratedrookie's Avatar
Okay I'm posting this for someone else with a '91 Toyota pick up truck, 2WD, reg-cab, 22RE, 5-spd. The truck has about 140K miles.
This may be difficult to put into words, but I'm going to try. Basically the truck has some type of a vacuum or gasket leak somewhere. When you start it up the engine revs to idle then bogs and continues to do so. Sort of like this:
Rev...Bog...Rev...Bog...Rev...Bog and so on.
Is there anything specific to these engines where this may be a common issue? What should we look for in attempting to solve this problem?
Thanks in advance for any help.
Old 02-25-2006, 12:41 PM
Tacoclimber's Avatar
Did you check the timing?
Old 02-25-2006, 12:45 PM
toyotaoffroad91's Avatar
sounds like an idle surge could be a vacuum leak and it could also be that the idle speed is set to high.
Old 02-25-2006, 04:17 PM
peterng's Avatar
idle surge
Eh,
sounds like it could be the classic idle surge.
sometimes the idle adjustment screw located on top of the throttle body tends to back off over time and causes this condition which is not necessarily sympomatic of the resulting condition, but is very typical.
try turning the screw clockwise and see if that cures it.
give a shout if you need help locating th idle adjustment screw.
Good luck with it !
Pete
Old 02-25-2006, 04:23 PM
peterng's Avatar
oops
errr,
sorry toyota offroad, just noticed you noted the same thing.
Pete
Old 02-26-2006, 05:41 PM
Bobakazi's Avatar
Try spraying some starter fluid around the throttle body, intake, and vacuum hoses. If the rpm's bog and stay there for a bit, you have a vacuum leak. Check your hoses, you might need some gasket sealer.
larrys93pickup
09-17-2015 07:05 PM
Patrick1976
09-15-2015 11:33 PM
Corvoid
09-14-2015 10:10 AM
old87yota
09-09-2015 12:39 PM
EatChipsNow
09-09-2015 01:25 AM
Quick Reply: help diagnose problem w/'91 truck
