HELP acceleration issue, lack of power
Old 03-07-2013, 12:36 PM
stanprophet's Avatar
Originally Posted by BamaYota1
You can attempt to clean the contacts on the VAFM. Just cut the silicone around the box, and the plastic can be lifted off. Google search adjusting it, and you will find a decent write up. It is a pretty simple device.
I would still check the O2 with an oscilloscope. Iirc, the engine does still read the afm in open loop, but I could be wrong about that.
Yes it will rear the AFM in open loop, but does not use the O2 sensors until the engine reaches operating temperature and it goes into closed loop. It will use the AFM, TPS, and RPM to calculate AFR based on standard fuel maps. The fact that it runs fine while in open loop, and has no throttle problems leans towards an O2. If the AFM has an issue it normally would be like that all the time, same if it were an issue with the TPS.
Keep in mind this is generally the case, Being a Diagnostic Technician, I have seen my share of things that defy logic, and normal failures.
I am going to do some testing in my truck just for the hell of it, and I never recommend throwing parts at problems, check them first then fix it. But if your 02 sensors are original, or have a ton of miles on them, they are likely due to be replaced anyways. If anything it will help the overall efficiency of the engine.
Dave
Old 03-07-2013, 12:39 PM
Darryl01088's Avatar
My 92 had a similar problem. Turned out to be the MAF. I found it by tapping on it with a screwdriver while engine was idling. The engine would stumble and die.
Old 03-07-2013, 01:10 PM
The good old "Wiggle and Tap test"
Old 03-07-2013, 01:17 PM
HunterRunner0122's Avatar
Mine is probably the o2 sensor cause I don't have one lol. The p.o did this. He replaced the manifold with one that didn't have the bung for the o2 sensor and the plug is just hanging there. I'm getting another manifold tonight and o2 sensor. I will let u know if this is my problem. My afm tested fine according to the FSM but I'm still getting the code for it. I have rest it it too and it's still there. Hopefully the new manifold and o2 sensor will fix the bogging.
Old 03-07-2013, 02:28 PM
  #25
BamaYota1's Avatar
Only buy a Denso direct fit O2! Don't waste your money on Bosch or anything else. Our trucks are very picky. You can buy the correct Denso sensor off eBay for 40-50 bucks.
Old 03-07-2013, 02:42 PM
  #26
Its got one in it already and its a denso so I'm going to try it out first and see what happens. Thanks for the heads up
Old 03-07-2013, 07:23 PM
  #27
Co_94_PU's Avatar
... My afm tested fine according to the FSM but I'm still getting the code for it. ...
Test the wires at the ECM, voltage and resistence checks per the FSM computer section.
Old 03-08-2013, 02:35 PM
  #28
I tested it there and it looks good too. would not having an o2 in make the ecu think there is something wrong with the afm?
Old 03-08-2013, 02:45 PM
  #29
Yoyaslave: had any luck with yours? I was going to put in my new manifold last night but I dropped it and broke the o2! If aint one thing its another lol. So I ordered another one today from advance auto, there like $30 with a $10 rebate for the denso.
Old 03-08-2013, 02:51 PM
  #30
BamaYota1's Avatar
No. You either have a wiring issue, or an afm that is bad.
Old 03-08-2013, 03:00 PM
  #31
Even tho it tested good, it could still be bad? After I get the o2 in I'm going to put my buddies afm in and see what happens. Thanks for all ur help by the way.
Old 03-08-2013, 04:48 PM
  #32
Co_94_PU's Avatar
Which code exactly are you getting persistently?
Old 03-08-2013, 04:59 PM
  #33
2,5&8
Old 03-09-2013, 07:07 AM
  #34
Thumbs up Bogging down fixed!!!
I installed my manifold and new o2 sensor this morning and...... NO MORE BOGGING . . I took out the EFI fuse and cleared the codes and drove it about 5 miles and got back home and checked for codes again and nothing so far. It ran really good but i did notice a miss ( engine stumbles for just a second) around 2500 rpms. . Im still going to put my buddies afm in tonight when he gets home and see if it runs even better. Thanks for every ones help
Old 03-09-2013, 01:25 PM
  #35
yotaslave's Avatar
Dropped your manifold!? Ahh!! I'm really glad that fixed your problem. I haven't had time to test my TPS yet (though it's on my list). I put the AFM from our other Toyota into mine and it's running better (less drop in power and more acceleration before the drop). I ordered the O2 sensor a couple days ago and it's here so I'm going to plug her in and see how she does. Hopefully this was my problem as well, fingers crossed(: Thanks for the update!!
Old 03-09-2013, 01:27 PM
  #36
Good luck!
Old 03-10-2013, 03:30 PM
  #37
yotaslave's Avatar
O2 didn't work.
Old 03-10-2013, 03:32 PM
  #38
yotaslave's Avatar
Do I need to take out my efi fuse and clear codes??
Old 03-10-2013, 03:33 PM
  #39
BamaYota1's Avatar
Yes. What do you mean it didn't work?
Old 03-10-2013, 03:45 PM
  #40
yotaslave's Avatar
I replaced it and it ran better for awhile but then it cut out as usual.
Quick Reply: HELP acceleration issue, lack of power
