HELP !! A340H - no 2H position since 2"BL
Old 03-02-2008, 01:22 PM
Mcdoggy2000's Avatar
Unhappy HELP !! A340H - no 2H position since 2"BL
I really need your help.
Installed 2"BL form 4crawler with 2" AT link drop bracket. (it was recommended more than 2" BL)
First, complete BL and test drive, evrything is fine, gear position on AT shifter was little off and hard to get "P" from "R"
2H-4H-4Lo all gear was there.
Adjust "P" position and location was all good.
Then Installed 2" AT link drop kit. I notice "4WD" light is on.
Transfer case position is "2H" then "4H" was ok, but I can go "4Lo"
Then I found out shifter at 2H is "4H" gear, shifter "4H" is "4Lo"
I tried to adjust transfer case linkage, but Can't find "2H" position.
Please share your experience adjusting transfercase position.
I just couldn't find info.
Thanks
Old 03-03-2008, 08:09 AM
Jay351's Avatar
Are you sure your shifter is not binding on anything? Remove the cover and check for free movement.
Old 03-03-2008, 08:14 AM
04 Rocko Taco's Avatar
who needs 2WD?
no more pavement for you, looks like you can only wheel for the rest of your life, you may never return to work or home. just wheelin offroad forever.... doesnt sound so bad.... I wonder if I can mess up MY 2WD....
*runs off to tinker*
That is all...
Old 03-03-2008, 08:20 AM
mt_goat's Avatar
I'd shoot Roger an email or PM, I'm sure he will have an answer.
DeclansDaddy
12-29-2014 06:04 AM
95Runner4x4
02-24-2013 01:46 PM
Numbchux
Domestic Swaps
19
03-31-2011 12:57 PM
AaronW
04-19-2007 05:33 PM
Quick Reply: HELP !! A340H - no 2H position since 2"BL
