Heater control valve compatibility between 22re / 3zve
Old 11-21-2013, 09:00 PM
stevennc's Avatar
I have the 3.0 and it finally got cold enough to turn the heater on. I noticed a leak coming from the heater control valve right below it were the screw and cable connection are. I pulled it off cleaned it up lapped the surfaces, but still have a leak so time to replace.
Is the heater control valve the same between the 22re , 3.0 and even for the t100 of my year 1993? The t100 looks exactly the same online, and is significantly cheaper from an auto parts store. I also have the option of plucking one from many trucks at the yards with 22re's if it fits.
Old 11-22-2013, 09:51 PM
stevennc's Avatar
nothing?
Old 11-23-2013, 12:13 PM
4runrjunkie's Avatar
sorry i dont have an answer to your question, but I am about to replace mine today hopefully and was wondering if you had any tips on replacing it. It looks fairly simple but tips are always helpful haha.
Old 11-23-2013, 02:13 PM
stevennc's Avatar
If you have caps cap off the hoses . You can do a flush of the heater core while you have it apart as well. It is pretty simple one fastener and then the cable mechanism. Ill probably end up buying a new one from napa today myself. The one for the t100 is 31 while the pickup is 45. I may compare them side by side or just suck it up and buy the one for 45.
the1998sr5
15
07-14-2020 08:35 PM
09-04-2015 09:27 AM
1994toyota
07-17-2015 03:03 AM
sojourner567
07-16-2015 08:52 PM
voiddweller
07-15-2015 03:56 PM
Quick Reply: Heater control valve compatibility between 22re / 3zve
