YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-23-2007, 10:46 AM   #1 (permalink)
Granddental's Avatar
Gearing Help Again Please
Hey Guys i have an 87 4runner with 31"s and the factory 4:10. however iam at 2900 rpms at 60 miles per hour on the freeway and shes a total dog going up any incline on the freeway. i thought about 4:88"s but i just realized thats going to bump my rpms at higher speeds. So 4:59"s was the next thought but i dont want to be at 3500rpm doing 60. so any help would be appreciated. I would love to eventually get 32 or 33 onches tires but i dont know thanks again.
Granddental is offline
Sponsored Links
To remove this ad, register today!
Old 08-23-2007, 11:10 AM   #2 (permalink)
AxleIke's Avatar
First of all, what is all of this concern about RPM's?
I ran my 4.88's with my stock 28.5's for almost a year, and it was fine. I couldn't go 80mph, but 65 was fine. 65 was about 3k.
Keep in mind that these 22RE motors are just barely getting into their power band at 3k. I routinely will run mine on the hwy at 3500, and 4-4200 to climb hills.
If you plan to go to 33s, get the 4.88's.
__________________
IFS SAS
My mods aren't bling enough for the signature line.
-All Terrains are for when you know how to drive.
AxleIke is offline
Old 08-23-2007, 01:14 PM   #3 (permalink)
Jay351's Avatar
Send a message via MSN to Jay351
if you really want to regear for the 31" tires then you should go with 4.56 gears. Alot of trucks came with them if they have factory 31" tires (and a 5sp)
But if you plan on going to 33" tires in the next year or so, I would just do 4.88's If you don't you will be right back where you started and will have spend all that money to regear again.
so.. In my opinion.
live with it, OR go with 4.88's
__________________
91 Pickup - xcab - 5sp - 3.0 - sr5 - 4x4 - 230,000kms |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs |Diff breather mod | Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |Downey idler arm brace|hella E-codes| Marlin armor | %100 Amsoil synthetic
http://www.cardomain.com/ride/2572486
Jay351 is offline
Old 08-24-2007, 05:51 AM   #4 (permalink)
TNRabbit's Avatar
Yeah, the 4.10 is a bit tall for 31's.
__________________
TNRabbit
Stock '94 DLX XtraCab 4x4 5 spd, Newly Rebuilt 3VZE, 2006 Taco 17" Alloys, 224k miles, AISIN Hub Swap Kenwood Double-DIN Head Unit, 1x 290 watt Kenwood Amp driving 2 Klipsch speakers, 1x Kenwood 1000 watt sub amp driving 2x10" Infinity Perfect 10.1D subs
TNRabbit is offline
Old 08-24-2007, 08:33 AM   #5 (permalink)
ZUK
ZUK's Avatar
Quote:
Originally Posted by Granddental View Post
Hey Guys i have an 87 4runner with 31"s and the factory 4:10. however iam at 2900 rpms at 60 miles per hour.............................................. ..
Are you sure you have 410 gears? In 5th gear you should be turning closer to 2400~2500 rpm.
By the way, I had an 87 Runner....22RE and auto......I added 571 gears and skinny 33" tires....it would do 2720 rpm at 60 miles per hour.....it was 'zippy' on the highway ....no problem with the inclines. You might want to look closer at your engine....spark plugs,timing, clogged exhaust.
__________________
www.gearinstalls.com
2001 white Xtra-cab Taco 3.4L auto TRD
88 Runner/V6/auto/31"/5.29gears
ZUK is offline
Old 08-24-2007, 08:48 AM   #6 (permalink)
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
It also depends on what you mean by "a total dog". I mean, it is a four cylinder engine. You're not going to a lot of power under those circumstances, anyway. Atleast, not with a stock engine and drivetrain. Even with 30x9.50's and a stock engine (with a full tune-up) I can't make it up freeway inclines very fast. I get passed quite a bit. In which case, I just take it easy or stay off the freeway altogether.
__________________
Matthew
Context is everything....
Quote:
Originally Posted by abecedarian View Post
freckles, shmeckles... that was your acne reflecting on my pearlescent skin.
Get smacked....join chat!
http://www.yotatech.com/misc.php?do=flashchat
thook is offline
Old 08-24-2007, 09:07 AM   #7 (permalink)
ewong's Avatar
BTW - manual or auto?
ewong is offline
Old 08-24-2007, 09:12 AM   #8 (permalink)
Jay351's Avatar
Quote:
Factory 4.10 gears - I assumed an 5sp.
I dont think auto's came with 4.10s
__________________
Jay351 is offline
Old 08-24-2007, 09:12 AM   #9 (permalink)
thook's Avatar
Now, that's a good question. If it's automatic, you won't have 4.10's if it's all still factory. In other words, no one swapped the gears out. Then, you should have 4.30's. If it's a manual, then it will be 4.10's. Unless! You have a V6. ????
__________________
Matthew
thook is offline
Old 08-24-2007, 09:13 AM   #10 (permalink)
runethechamp's Avatar
2900 rpms at 60 miles per hour??? That doesn't really rhyme with anything. With those numbers your speedo thinks you have the normal 225/75 wheels and 4.88 gears (of course assuming MT and V6 engine since those are the numbers I have available).
__________________
94 4runner SR5, V6 3VZE, 5 speed
Completely rebuilt engine with Toyota parts at 147k miles
Downey Coils, Aisin manual hubs, Cowl Louver mod, Hella 500 fog lights
Yeah, I know, not many cool mods here
runethechamp is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Gearing?!?! 85yotalover 84-85 Trucks & 4Runners 7 04-19-2007 08:29 PM
Gearing?? coot 95.5-2004 Tacomas & 96-2002 4Runners 5 01-21-2007 11:10 AM
Re-Gearing ErikJeanna 95.5-2004 Tacomas & 96-2002 4Runners 16 08-12-2005 09:36 AM
Gearing???? standarche 95.5-2004 Tacomas & 96-2002 4Runners 9 06-08-2004 03:49 PM
Gearing ?'s AznSky Offroad Tech 35 12-31-2003 08:04 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
