Gas tank holes
Gas tank holes
My 1988 Toyt Truck 22R 2 Bbl carb has a couple tiny holes in the gas tank.
My first attempt at patching them up didnt work using Auto Parts Gas Tank repair patch kit. Now I tried again and waiting for it to dry a day later to see if it will work.
If it still leaks is there a way to weld or patch weld a Gas tank to stop my leaks? The 3 tiny holes are in one part of the tank and the patch I am trying covers about 3 square inches.
You can use bar soap as a temporary patch. Just take a bar and rub it hard against the holes and it will plug them for a while.
There are various patch systems available, but I have never had very good luck with them.
Welding on a used gas tank is a job that is best left to professionals. The tank must be dropped, purged, filled with something inert and then and only then can it be safely welded on.
Thanks,
I will take it to a pro but wanted to make sure that is possible to do on an old gas tank.
I assume I can get quotes from body shopes but wasnt sure if patching a gas tank was possible.
Originally Posted by oaklander
Thanks,
My Permetex patch seems to have worked on the 3 small holes.
My last patch lasted about 5 years.
Anyone have any advise or knowledge on how long patches last on gas tanks? My tank has no rust visible from the outside.
I will also put rubber undercoating over the patch area.
skoti89
09-11-2015 07:46 AM
pyramid
07-30-2015 10:05 AM
pyramid
07-29-2015 06:53 AM
